thickest 2x2 square tube to fit receiver hitch
   / thickest 2x2 square tube to fit receiver hitch #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
What is the thickest square tube that would fit a receiver hitch (please don't say solid). This will be used on a subsoiler on the back of my counter weight.I tried a piece of 11ga. I got from work and it bent.Need thicker wall tubing.Will 2x2 1/4" fit in the receiver? Thanks for the help. 100_9667.JPG
   / thickest 2x2 square tube to fit receiver hitch #2
Isn't tubing sized by the OD (outer dimension)? 2x2x1/4 or 2x2x3/8 or 2x2x1/8 are all 2x2 on the outside....Or am i missing something here?
   / thickest 2x2 square tube to fit receiver hitch #3
That's how it is in Missouri. :D
The thicker the wall, it looks like the outside corners are more rounded. I don't work with a lot of structural square tubing.Want to get help from someone that does.I may be missing something too, That is why I asked!
   / thickest 2x2 square tube to fit receiver hitch #5
I've built several. Usually use 1/4" wall.
Where a problem appears is if you try to use normal square tubing to make the female part.
   / thickest 2x2 square tube to fit receiver hitch #6
I built a hitch for my truck and used 2x2x1/4".
   / thickest 2x2 square tube to fit receiver hitch #7
Why not use solid bar stock?
I have trailer hitches made from it & they work fine.
   / thickest 2x2 square tube to fit receiver hitch #8
Yup, any 2x2 square tube will fit in a receiver hitch, as square tube is on the outside dimensions, not the inside like Pipe.
In 2x2, it appears 1/4" wall is the thickest offered.
I did make one from solid for a truck (what we had on hand at the shop)I was trying to cut down on the smart a** comments.I wanted to make sure the 2x2 1/4" would the best with the receiver. Thanks for the help!
   / thickest 2x2 square tube to fit receiver hitch #10
Why do you want hollow tubing instead of solid on a subsoiler? Just asking.
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
2018 Dodge Ram 5500 4x4 Crew Cab Utility Flatbed Truck (A55973)
2018 Dodge Ram...
2016 Ford Explorer (A56859)
2016 Ford Explorer...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
