Thermostart problems. ARRGH!
/ Thermostart problems. ARRGH!
This is an informative thread. I have never heard of a thermostart before, now I have. If you are like me, here is an article that explains them; Inside a Yanmar thermostart (glow plug) unit.
Thanks, but I already knew how they work. The problem is that I have 3 new ones and they all don't work. If I could get an original one maybe it would work.
Eric
I was talking with my son a few minutes ago about how my original thermostart worked and how the new ones work. And I told him I was hesitant to buy another because I've had 3 Chinese ones fail. I wondered out loud about driving a punch against the little ball to increase the clearance a tiny bit so that when the thermostart gets hot fuel will flow. But if I hit the ball too hard the thermostart will leak the whole time and that would be bad. My son suggested using a solenoid valve. That's a great idea. Then the tractor will work the way it used to. Now I gotta find a small 12 volt solenoid valve that will handle diesel fuel.
Eric
Well, I went and ordered a 12 volt solenoid valve that is diesel fuel compatible. The valve body is brass. It should be here by Sunday. Hah! Mail is so bad here on the island I won't hold by breath. But I will use the time to figure out how to mount the valve. There are drawings online showing mounting hole dimensions so I will use that info to fab a bracket or something to fasten the valve to. I am going to experiment smacking the ball with a punch and if the thermostart leaks when cold then I will install the valve. One really nice feature using the valve will be the ability to use the timer in the tractor. At least I think there is a timer. The red light on the dash only stays lit for a short period of time but the thermostart coil stays energized as long as the key is turned to the left. I think the reason there is a box on the firewall with a wire coming out that goes to the factory thermostart is because it powers the thermostart valve for only as long as the dash light is on. Anyway, I will post about how it all works out.
Eric
UNUSED IRLMC DELUXE MASSAGE CHAIR (A64281)
UNUSED IRLMC...
500 Gallon Hydraulic Oil Holding Tank (A61573)
500 Gallon...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
