Thermal Lancing (yikes!!)
   / Thermal Lancing (yikes!!) #31
Yes - that tapered cross pin is what we call a cotter pin. What you would normally call a cotter pin, we would call a split pin. And remember any circlips(snap rings) you may leave under the bonnet (hood) or wing (fender) when collecting your spanners (wrenches):D
Can you please repeat all of that? I love listening to your accent!
:D
   / Thermal Lancing (yikes!!) #33
Actually it's two totally different processes.
Carbon arc gouging, air arcing, gouging uses a ....surprise LOL...carbon rod 1/4" + or so in diameter. You need a welder with lots of amps and a compressor with lots of air. You hold an arc between the item you're gouging and the carbon rod which turns the metal molten. The air is directed in the area of the arc and blows the molten metal away. Big shower of sparks which travel a significant distance. More commonly used for backgouging welds or removing broken/cracked welds to get to good material.
A thermal lance, slice torch, is an exothermic process, once you get metal rod hot enough, you feed pure oxygen to it and it will be self sustaining i.e. burning. That's why people using torches in a shipyard for example and called burners not cutters. You can do the same thing with an acetylene torch if you have a piece of clean plate. Start the cut and turn off the acetylene and oxygen, just using the cutting oxygen and you can keep the cut going......Mike
Yes......^^^^^^^..........this
Thermal lance (or Oxy-lance I call it) uses an electrode that resembles a piece of Thin-walled steel tubing with thin wires of magnesium down the length, the electrode is lit by striking it on a copper pad connected to a 12vdc battery. The stick stays lit and eventually burns itself up, a pull of the trigger gives a high powered shot of oxygen and it looks like a giant sparkler. The magnesium reacts with the oxygen to give it the heat and the Oxy pressure helps push out the puddle while plunging.
   / Thermal Lancing (yikes!!) #36
Way back when, we used to cut automotive die bolster plates and dies into moveable sections, but we used a large lance with a gas driven air compressor for air. We could cut a 14" thick solid steel plate or die any width (width was dependent on how much blow we used.). Dirty messy and had to be suited up in Nomex.
Cut like butter. Used a 5 foot long tubular lance (steel tubing) fillet with phosporus rods (sparklers) for lack of a better term. Started it with a gas axe and turned on the blow.
   / Thermal Lancing (yikes!!) #38
Hard to justify buying one for a one time use, but might be able to borrow/rent one. Doesn't take a lot of skill. I was sent to the coal mine to lance a 8" diameter nose cone pin on a haul truck and had never used one before. Got it done. Was a miserable job. Went through I don't know how many rods and a couple of oxygen bottles. The pin was probably 18" long or so. Ours wasn't fancy either. Just a holder with maybe an oxygen lever and you light it with a torch.
Removing that pin by exothermic lancing is not going to be cheap at almost $2000.00. I think I could cut the whole thing off and weld another section back on a lot cheaper.
Arcair Slice Battery Pack, 12V AC 6 Hz - 6399141 Baker's Gas & Welding Supplies, Inc.
   / Thermal Lancing (yikes!!) #39
I prefer the ambient compressed air ones myself. No bottles to contend with, just the engine driven compressor. Pretty easy to build one actually and the lance rods are available at most LWS, at least at Air Liquide they are.
   / Thermal Lancing (yikes!!) #40
Actually I think the one we used was probably shop made. If you watched wdchyd's videos, what we used was the long rods like the second video. They had a little learning going on in that video probably similar to what I had. The shop also had the small lance like in the first video which would be ideal for the OP's pin. I'm guessing the oxygen works better than compressed air because of it being an oxidizer, but don't really know. Compressed air works fine for air arcing. Seems I ended up with higher oxygen pressure than the 100 psi because of having difficulty getting the slag to flow out of the deep hole. It's been 25-30 years ago that I had that experience.I believe we did that for the Cat dealer. They had had 200 ton on that pin and couldn't move it. Took about 50 tons after we got a hole through it and it had cooled some.
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
2012 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
2012 JCB 930 ROUGH...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
1999 FORD F-450 SUPER DUTY SERVICE TRUCK (A54756)
1999 FORD F-450...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
