Therma start
/ Therma start #1
Swblack1216
Washington state
Kioti ck25, Ford 4500
I am installing a thermostart in my Ford 4500 diesel. I’ve put it into the intake manifold and it’s wired to the ignition. I tried using just a canister above gravity, feeding diesel to the thermostart that did not work. My question is if I T into the return lines by the Injectors will that work?I have never seen instructions on how it’s done
/ Therma start #2
Many many tractors use a reservoir with gravity feed to supply a thermostart. If yours doesn't work you need to explain what you used and how you put it all together. Done correctly, no reason for it not to work.
/ Therma start #3
My old MF35 has had one in there for who knows how long with nothing hooked to the diesel line before I bought it. Hit the power and it gets hot but the valve doesn't seem to open.
I made a reservoir that goes between the returns and the tank. I will keep trying and see if the penetrating power of diesel will eventually get it working. You can just buy a new one, which I will probably do once I'm sick of using ether to get it started. It's definitely a slow project though and there is a lot of blow by so it might need a rebuild rather than just a new thermostart...
/ Therma start #4
Last year I bought 3 thermostarts. None worked more than once. I bought another one about a month ago but haven't felt like putting it in just to be mad because the darn thing won't work. Again. And no, it is not because I am doing something wrong. They get plenty of gravity fed diesel, they get red hot, but diesel does not dribble out. The best luck I have had is one that worked once. Both heating coils get red hot, but no diesel leaks out of the end. I took one apart, I understand how they work, but even though purchased from different vendors they all appear to be made in the same factory with the same crappy quality control.
Eric
/ Therma start #5
Buy the real one if quality is sub-par on the clones.
The real Thermostart is (was) a Perkins patent. Apparently now expired.
I bought an authentic Perkins one from a shop that serviced ThermoKing (refer truck) refrigeration units, that are powered by a Yanmar diesel. To replace the OEM (Nipon Denso, under license?) unit that died.
Not expensive, $15 in 2007.
dscn5123thermostart-perkinsbox-jpg.68476
So far as I know there are only two versions. For slide-on terminal, or one where the tab is threaded for a screw to attach the wire. A slide-on connector also fits fine onto the threaded tab.
/ Therma start #6
What you show is what I bought. Same box too for one of them.
Eric
/ Therma start #7
Eric
Strange that those didn't work. The one I got in that authentic box still works fine in my YM240, some 15 years later.
I bought another Thermostart when I got the first YM186D about 2010. The cheapest one on Ebay was a generic from London. It worked fine for the 5 years I had that Yanmar.
And the original (?) one in the YM186D with loader I own now, works fine.
In all cases 15~20 seconds after twisting the key left, there's a pop as the fuel ignites. I posted a photo of that flame on here long ago that ended up being the illustration in Hoye's description.
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2010 Mercury 15HP Tiller Outboard Boat Motor (A61574)
2010 Mercury 15HP...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A59911)
2016 INTERNATIONAL...
2022 EZ-GO ELITE...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
Caterpillar D6R Dozer Service Manuals (A63117)
Caterpillar D6R...
