There goes the O ring, AGAIN!
/ There goes the O ring, AGAIN! #1
Yardscaper
St. Louis, MO
Polaris ASL 300, 1959 Economy Tractor
I am wondering if anyone else out there is having problems keeping o rings in their backhoe. I have gone through countless o rings in the backhoe manifold. We keep extras on the truck and can get no answers from Power Trac. I was just curious if anyone else had experienced this, and if so, how did you correct it? It is frustrating! /forums/images/graemlins/confused.gif
No one has had any problems like this?? Am I the only one?? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
/ There goes the O ring, AGAIN! #3
I only have the 425 and the small mini hoe so can not help you.
PJ
/ There goes the O ring, AGAIN! #4
Are you using o-rings from PT, or a generic look-a-like.
If you are using the correct o-ring for your manifold, there are two possibilities, there might be a sliver of metal floating around, and if the o-ring is on a spool, it might have a burr on it. I would break it down completely , clean throughly, and using a magnifing glass look at every thing carefully. Grit and metal slivers cause most of hyd problems. Wrong o-rings cause the other problems. Hope you find the problem.. Good luck.
/ There goes the O ring, AGAIN! #5
Yardscraper,
Does the oring manifold operate okay at first, and then leak after a period of time. Size, material, durometer of the oring are critical, as well as size of the manifold oring seat (cleanliness like mentioned). If it is okay at first, then starts to leak, is heat/vibration causing a the manifold bolts to loosen.
Duane
/ There goes the O ring, AGAIN! #6
I'm in the midst of a similar problem with my post-hole digger. The female quick connect from the PHD has gone out twice now in two days. It's not a hard problem to fix, but at this rate it will get very annoying. I've checked for burrs on the male portion, but can't seem to find anything.
STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
STARCRAFT BUMPER...
Hardi Pull Type Sprayer (A64047)
Hardi Pull Type...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
7102 (A61567)
7102 (A61567)
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
