The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #451
OH NO. Are you telling me now that we'll be forced to make a smaller opening grapple? :eek: With cylinder stops sized just right, I think it can be arranged.
Travis
You are on the perfect path. Larger for those that need larger yet are not skid steers. Your current line in great for the smaller to medium compacts.
How much do you want down for a May delivery?
Ted says that since the floating tailgate models are complete, the retractable shank box blades will be next and May delivery is very possible.
I will definitely share everything on here when the time comes!
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #453
I might have missed it, but what is the definition of a Mega-Compact (MCUT)?
:) I think I might have one......maybe? (41 HP)
   / The WICKED Root & Debris GRAPPLE!!!!!!! #454
Travis is the originator so he'll have to decide on the parameters. I think he was trying to distinguish the original types of compact utility tractors (thinking of Kubota B and L series and JD 4600 for example) from some of the newer bigger CUTs that have much stronger loaders and mass. I would imagine he'd consider the Mega CUTs to be the ones that are too big (powerful, heavy) for the EA 50" light duty grapple. If that is the case then the cut off would likely be something like having more than 2000lb loader lift capacity but you'll have to get Travis to pin it down. The mega cut off would probably vary by tractor brand. Kioti and Mahindra are typically heavier at a given HP than Kubota or JD and tend to have higher capacity loaders (and front axles to match). I could imagine a 40hp Kioti considered different than a 39hp Kubota for example even though the power is nearly identical as the Kioti is heavier and has a more powerful loader.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #455
Travis
Travis, I'll give you a jingle Monday. Have a good weekend.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #456
This just in.....
Introductory prices for the new single lid Wicked Grapples are:
54".....$1,690.00
60".....$1,719.00
66".....$1,774.00
72".....$1,831.00
The lid will be 36" wide and the opening is 39.5"
Lead time is approx. 7-10 business days.
Ted is going to send some computer generated pics over and i'll share them when they arrive.
Travis
Dang, $300 cheaper than what I just paid for the 60" with a 30" opening.....Hmmmm, now I am wishing I would have waited
   / The WICKED Root & Debris GRAPPLE!!!!!!! #457
1) Shipping to a staffed commercial business or to the freight terminal in San Diego would only be around $100 for 400 pounds. No tax. :thumbsup: Travis
Thanks, Travis. You may get me as a customer yet! :)
   / The WICKED Root & Debris GRAPPLE!!!!!!! #458
Travis anything back on the computer generated pics?
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
2017 Freightliner Bucket Truck (A55973)
2017 Freightliner...
