The ultimate cheap canopy
   / The ultimate cheap canopy #1
srjones
Platinum Member
Columbia County, Oregon, USA
Mahindra 2015HST & Mitsubish R1500
Hey everyone, I need your help.
For the last few days, I've been driving by a fiberglass truck bed cover for sale. I stopped by and talked the seller tonight and this seems like the ultimate cheap canopy if I fab up a frame for it. The problem (which is maybe an advantage) is that this thing measures roughly 62"x64" which is wider than my tractor. :eek: I'm not sure how it would look either, but I'm really not to worried about that. However, it would be nice not to have small children pointing and laughing as I drive down the street. :p
The advantages I see are multiple:
1) Ultimate shade
2) Ultimate rain cover (it rains alot around here)
3) Good durability (this was designed for a truck bed)
4) Good price. The guy wants $50 for it.
So, the question: Should I go for it? Usually I wouldn't think twice about buying this, but money is tight at the moment and I'm questioning everything. For what this is (and what it could be) I'm thinking I'd be passing up a steal if I didn't.
I just need a little push to go get it, or some reasons why it would be a bad idea. Thanks.
-Steve
   / The ultimate cheap canopy #3
It would be sort of like building a shed for your tractor............and taking it everywhere with you. :)
Well, fearing it might be sold before I could get to it and after making the original post, I jumped in the truck and drove 6 miles back down the road to buy it. I think I convinced myself to buy it just by writing about it.
And.......I think I lucked out. The color seems to match pretty well and it doesn't look too oversized. But it is big...and flat..but that's ok. At a certain angle, it does look the Flying Nun's habit....(good thing the tractor doesn't go that fast).:D
Also I didn't realize that a fiberglass tonneau cover typically goes for more than 10x what I paid for it, so this is the "Ultimate Cheap Canopy" only if you buy it cheap. :p
So anyway, thank you ToadHill and JoeinTX for giving me that little push I needed, even if I didn't wait long enough to even read them.
-Steve
More pictures to come this fall when I figure out how to securely mount it and redo the lights.....
   / The ultimate cheap canopy #5
Looking at first picture, it kinda looks like a racing stock car and I looked at the size and it came off a short bed small truck, it could have been worse if it was a long bed full size truck. Looking good and mount your lites at the front and reat edge and you will be fine with some front supports
   / The ultimate cheap canopy #6
srjones:
I had the same thought as you about using a fiberglass pickup box cover; but I never found one cheap enough to get one. So I bought a factory made unit from Femco.
I hope you post more pictures as you come up with a permanent mounting frame for it.
   / The ultimate cheap canopy #7
"So anyway, thank you ToadHill and JoeinTX for giving me that little push I needed, even if I didn't wait long enough to even read them...."
It actually looks not bad at all and as a poster above said the paint seems to match. If you can fab-up the frame to support it, you're golden.
There's never too much shade when running a tractor and rarely an "aesthetics" debate over what you've done to make it more comfortable.
If someone doesn't like it.............***** them.
@MrJimi,
I didn't write it down, but I think the guy said it came off a 2002 Dodge Dakota shortbed. The dimensions were actually larger than I first reported.
@mjncad,
I've seen your posts and really I like what you've done with the ROPS mounted canopy...and the mirrors...and...;). However, right now I'm torn between doing something like that versus building up full front supports which would lend itself to eventually enclosing it in. Also, the 4 post design would give me more places to attach stuff (mirrors, gunracks, toolbars, etc). But then again, your design seems aesthetically cleaner. Oh, I'm torn...TORN I tell ya. :D I'm sure when the rains return I'll make up my mind real quick.
   / The ultimate cheap canopy #9
Four poster would be ok, but if you can make a strong enough one using a two post support you will probably like it better in the long run due to visibility problems with the front posts. If you do have to go with the front posts, make them see thru as much as possible.
David from jax
   / The ultimate cheap canopy #10
Great coverage! Looks good. Watch out when you work near trees. Any lean will make you real wide.
larry
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2022 Kubota B2601 (A50120)
2022 Kubota B2601...
JCT 84" Rock Grapple (A50121)
JCT 84" Rock...
