The shop crane transition
   / The shop crane transition #11
no just convert that cylinder on the shop crane to hydrolics to run off your side link control and there no annoying pumping that has to be done!
   / The shop crane transition #12
Any reason why one couldn't use a backhoe (Woods BH80) to do the same job? Would I tweak my backhoe?
   / The shop crane transition #13
This is the hydraulic boom lift I made for my powertrac 180. It works great, but my lift arms are only rated at 600 Lbs, and the 2" bore x 14" stroke boom cyl will lift a lot more than that.
Now that's what I would call a real cherry picker. Nice job!
Had thought about that. It would make it alot more versital. I knew I should have bought a 3 spool valve. :( The side link control works great in moving your load sideways about a foot each way.
   / The shop crane transition #16
Boom looks great. I was wondering what a 1500# oicnic table was until I saw the pictures.
Andy
Here is a picture of the crane put to bed.
   / The shop crane transition #18
That is very cool.
   / The shop crane transition #19
Again, thats a great looking place. I really like the three point boom idea and I almost made one of those and then decided to go with a little more height instead of lifting capacity. Here is a picture of the boom I made for my FEL. The boom is 14 feet tall so I can get about 24 feet of vertical reach. I used this boom for putting up the columns, trusses, and purlins on my shop. The boom is pinned in the bucket and then I put ratchet straps just to stabalize the boom.
Qubota, Thanks for the nice words. Some day I may upgrade to a little larger tractor with a FEL. It sure would help with the overhead work but should be happy with what I have. I picked up that 750 the day after my wife said it was OK before she changed her mind. ;) Must have caught her in a weak moment but she loves what I've done with it so far. :D
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
2020 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2020 John Deer...
