The screw log spitter hunt!
   / The screw log spitter hunt! #1
Everhard
Mulmur, Ontario
Kioti Ck2510
So I go thru a fair amount of wood each year (when I'm home it's the primary source of heat in the house) and usually I'm happy splitting with an axe - I generally don't get stuff that too large so the amount of splitting isn't crazy, well except the last load of butt end logs and other crazy cast off's... So the great log splitter debate kept me, myself, and I busy over many a beer arguing the merits of stand alone units, 3pt hydraulic units and finally the screw variety.
So after much debate (and many a beer) we concluded that I need a splitter in the long term for the nasty type knotted chunks, and the really big stuff that takes many a swing of the axe before it splits. Also I make maple syrup in the spring and the evaporator uses logs that are 2-3' in length, and ya those can be a bit more of a challenge to split as well.
But which is the best option... Ha! Ok, everyone says what they have is the best. Ok, so I've decided the best option for me is going to be a screw type splitter, of which there are 2 designs that I think are reasonable, work well, are safe. (ie I ain't stickin' no screw onto the rear wheel of my jeep!!! Lol!) One runs straight off the pto, has a platform of sorts under the screw and the other one is the type where the screw is attached to the post hole digger in place of the auger.
I want to keep the costs to a minimum so was trying to locate a used unit - either the so called bark buster, or one of those "Stickler" screws but have had no luck at all! Every time I find one it's already sold. So I thought I'd post up here, maybe some one has one kicking around they don't want? Figured this is the best place to put the "word on the street."
Btw, some other bits of logic for going with the screw version over a hydraulic unit is my tractor (Kioti Ck20) is no monster in the hp department so any hydraulic unit I use wouldn't be the quickest where-as everything I've read about the screw type is that it will split significantly faster and my tractor has more then enough power to run it efficiently. Also as a bonus I can use a post hole digger so that will kill 2 birds with one stone. And lastly It would have to be the monster of monster hydraulic unit to be able to split a 3' log.
So there ya go, if anyone can help me out, if you know a friend of a friend who knows some one with one of these units kicking around that they aren't using, let me know! :)
Everhard.
   / The screw log spitter hunt! #2
The splitting screws are always available on eBay.
You cannot buy a new, assembled screw splitter in the USA; banned by OSHA. You have to import "new" from Poland or England.
Common on tombstones: I WONT FALL ON THE SCREW WHEN I AM TIRED AND SLIP. I AM SMARTER.
I would purchase a 110/220 volt electric powered wedge splitter way before a screw splitter.
LINK TO EBAY: SCREW LOG SPLITTER | eBay
Yes, I've seen those, I've also found the ones that are made to go on the post hole digger, but after shipping the price seems ridiculous to say the least, hence hoping to find one used. At the end of the day if I absolutely can't find a used one I'll go new.
Why an electric powered wedge splitter?
E.
Unless I'm missing something these units won't handle any large logs? Either in diameter or length? And don't they run a hydraulic ram anyway?
E.
Btw - with regards to falling on the screw, reality is that's particularly challenging to do if there's a table right under the screw, and if it's the post hole digger variety you'll be even more challenged to fall off the tractor seat onto the spinning screw. (not to mention you'd have to figure out how to defeat gravity first and fall up into the screw - when you get that figured out, patent it!)
Frankly as some one who was once a professional chainsaw operator, with a huge amount of time spent using a chainsaw and knowing the very real dangers of that piece of equipment, using a screw wood splitter is practically child's play. Common sense goes a long way. Hence my comment about not attaching one to my Jeep - that I can see having all sorts of interesting issues cropping up!
E.
   / The screw log spitter hunt! #6
Used the log screw type splitter on 24+ inch chunck of oak and pushed it up against the wood screw behind a 8n ford. Dang near beat the arms off the poor tractor and it was hopping around with loaded tires. It was a quick lesson well learned. Renter stole it and sold it. I really wished he had a tractor and would have used it.
   / The screw log spitter hunt! #7
I have an old one out back, still solid, never used it before, but often wondered about it
   / The screw log spitter hunt! #8
The biggest danger I can see is if the palm of your hand hits the point of that screw while pushing on the log.
CATERPILLAR 259D3 SKID STEER (A51242)
CATERPILLAR 259D3...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2018 RoGator 1100C (A52128)
2018 RoGator 1100C...
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
