The rollover plow
/ The rollover plow #1
bjr
Eastern WA
Jinma JM354
My latest aqusition. Edwards 3500 14" 2 bottom rollover plow. It's missing what ever kind of cylinders and linkage to make it rollover. Would trying to adapt a hydraulic motor to it be a good idea? Or should I try and adapt new cylinders to it? I would kinda like to make it work again somehow. bjr
/ The rollover plow #2
"Would trying to adapt a hydraulic motor to it be a good idea?"
Couldn't say on that.... looks like two boat anchors got tangled togeather. Took me a minute to see the purpose in it.
/ The rollover plow #3
No cylinder required (at least for most of the rollovers). As you may be aware, these plows are for looonnnnnggg straight fields. Get to one end, lift and flip and turn and go back the same way you came with the other rear tire in the furrow....Once you get it on your tractor, you will get a better feel for what has to be done. Suggest you get a manual for it. Color indicates its a Ford....BobG in VA
/ The rollover plow #4
I think the problem is that he's attached it with chains rather than the 3 pt. Probably won't work well that way. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Looks like a little welding in needed also as each shoe is cracked. I'd be afraid of losing a piece before long. Pretty cool otherwise. I know Ford and Fergeson both had several companies making their plows, but I don't recall if Edwards was one of them. I do agree however, it does look like an old Ferge or Ford plow.
/ The rollover plow #5
Those are real nice set of plows . If you are in a big fielded you can not get any better then that.
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2022 EZ-GO ELITE...
