The Real Problem With the Titan Ballast Box
   / The Real Problem With the Titan Ballast Box #1
Suburban Plowboy
Veteran Member
FL
Kubota L3710
I got my Titan ballast box painted and attached. I had 700 pounds of sand waiting. The ads say it has an 800-pound capacity, and they say you can fill it with rocks or sand.
Guess how much sand it holds?
I have 350 pounds in the box right now, and it's nearly full. I believe it would hold 375. Add 375 to the weight of the box, and what do you get? Answer: 505 pounds. That's not 800 plus 130. It's not even 800.
Based on figures from a person who knows a lot about sand and concrete, at best, concrete would weigh 1.5 times as much, so I could conceivably get 560 pounds in there. That brings the total weight up to 690. That's a best-case scenario. It could be a lot less.
In order to equal the manufacturer's stated capacity, I would have to use metal. I could combine metal and other materials in order to avoid buying hundreds of dollars' worth of steel, but there is no way to do it without metal, if the figures quoted to me are right.
Gravel would presumably be the worst thing to use, because it would contain a lot of air.
I kind of think the ad should say something like, "Capacity (sand): 375 pounds." It never occurred to me to take the capacity of the box, look up the density of sand, and see if it would fit.
Still better than dragging a bush hog around everywhere.
   / The Real Problem With the Titan Ballast Box #2
If it is the one I am seeing it has 5.3 cu ft of space in it. If a cu ft of concrete weighs 150 lbs., that would get you pretty close to the 800 number (795). So, I would go with concrete if you want to get to that weight.
   / The Real Problem With the Titan Ballast Box #3
Might consider adding water to the sand.
Wet sand is a whole lot heavier than dry sand.
td
I am suspicious of the volume claim. The lightest figure I have for sand is 100 pounds per cubic foot, so 530 pounds for the box. I didn't get anything close to that.
   / The Real Problem With the Titan Ballast Box #5
It's a bummer for sure, sorry it isn't working out for you. Any sizeable rocks around your place you could add in? I assume they are heavier than sand?
I know a few people with lead in their arse I would be happy to have you haul around on your 3 pt. LOL :laughing:
   / The Real Problem With the Titan Ballast Box #6
The dimensions stated for the red box actually come out to a little more than 5.6 cu ft. You could get approximately 840 pound of concrete in the box plus whatever the box weighs. However - I would not want to put concrete in the box.
Whoever wrote up the ad for that box did not understand the vast difference - volume wise - between 800 pounds of concrete or sand or gravel.
   / The Real Problem With the Titan Ballast Box #7
Somebody did not know how to do volume to weight calculations. Maybe didn't even know how to calculate volume.
Not very nice :thumbdown:
   / The Real Problem With the Titan Ballast Box #8
The box is 24"x 24"x 15.7"= 2 x 2 x 1.308= 5.23cuft
concrete=150lbs/cuft x 5.23 = 785lbs
sand=120lbs/cuft x 5.23 = 628lbs
empty it weighs 132lbs
All info is subject to old guy calculations and internet info.....
   / The Real Problem With the Titan Ballast Box #9
Your calculations are correct - ruff dog. Unfortunately - those are not the dimensions listed in the ad for the red ballast box.
25.5" x 24.25" x 15.75" =9740 cu in. There are 1728 cu in per cu ft. 9740/1728 = 5.637 cu ft
   / The Real Problem With the Titan Ballast Box #10
I was going on the dimensions Amazon had for the green Titan box. I wonder what the dims of the OP's box??? Just a mistake? I know i'm having way more brain farts the older I get...I figure it is a good day when my feet are flat on the ground! :dance1:
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
4ft 3 Point Hitch Scrape Blade (A57454)
4ft 3 Point Hitch...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
