The new 700ft driveway
   / The new 700ft driveway #1
rogerius
ON, Canada
Kubota L3940HST
I started the summer weekend job on my property and the first project on this year is to put a 700ft driveway from the entrance gate to the site of the future house and barn. The driveway will have a portion of 250ft on a small hill with approx 8-10deg slope. I used so far my tractor with the box blade to dig out around 2" of soil; it is a hard soil and very compact, so I'm planning to remove just 4" of it. I"l use the 200lb geotextile material and then compact 6 of gravel. Do you see any potential issue here? I checked in one spot how deep the soil goes and just after 18" I found some layers of gravel/sand. Here are some pictures.
   / The new 700ft driveway #2
Looks like a good start. Not sure where you are in Ontario but I'm out East past Ottawa. For our driveway (300ft or so), we dug down deeper and removed all the topsoil/soil and laid down pit-run on top of that and then eventually a finish of fine gravel. I believe we dug down 18-24" however we did not use geotextile material which will help you if you do not dig out all the topsoil. Personally I would remove all the topsoil and have it placed close to the future house site and use it to finish off the area around the house if possible. That's just my personal choice and what has been recommended to me by several good excavation/driveway guys. Did the same thing at our vacation home in Maine when we built a 700ft drive.
   / The new 700ft driveway #3
Funny thing, when I put in my driveway entrance and culvert, I dug out all topsoil down to about 12-16", then brought in rock and crusher run. When the pro crew put in the full driveway (600 ft) about 6 months later, they decided the topsoil was firm enough and just put down fabric and rock. In the end, it came out just as good. I had to add rock in one soft section, but that's it. Saved a lot of work and expense by not stripping all that topsoil for the whole driveway, and used a whole lot less rock.
We did dig about a 18" deep ditch on each side of the driveway to enhance drainage, which surely helps.
I was thinking to dig more but my concern is to not transform the driveway in a long French drain (French drain - Wikipedia, the free encyclopedia) and also keep the cost and time down. I almost spent more then 30 hours just to dig and haul 4" of soil.
Did you dig the ditch after the driveway was done or before?
   / The new 700ft driveway #6
Dig the ditches before you lay gravel and lay a layerof gravel in the ditch to slow runoff/erosion ,Everything attachments has a video on how to adjust your box blade to trench the sides of your drive , I wish I had a flat field to build my driveway I had to go up alot more than 8-10 degrees and built it with a little John Deere 855 and cleared the trees and roots first 011.jpg008.jpg
   / The new 700ft driveway #7
Some years back I did a 900' driveway. The first part was already dug out and I continued that for a distance. But I noticed that I was digging a water holding trough. The last several hundred feet, I just laid down #2 crushed limestone (4") on top of the ground, then smaller stuff. The construction trucks packed it down good and tight.
IDK, it's not "the right way" but it seemed to work just as well.
   / The new 700ft driveway #8
During. Once the path was cleared through the trees of the right width, the went down the length with a track hoe (wide bucket) and formed the ditches. Then the rock was brought in after that.
   / The new 700ft driveway #9
I agree that it looks like a good start. $700 ft of geo-textile has got to cost a good chunk of change, but if you aren't removing all the top soil, it's a good idea. I agree also that you wouldn't want to simply make a french drain by filling a giant trench with loose rock. Ideally you would have thinner top soil, or an abundance of sand nearby to work with.
Those stakes and strings would really tick me off after a few passes though, haha!
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2023 Top Hat Industries Cool Down Trailer (A52377)
2023 Top Hat...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2002 Ferguson SP915RE Ride-On Pneumatic Asphalt Compactor (A52377)
2002 Ferguson...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
1965 Rodgers T/A Equipment Trailer (A53117)
1965 Rodgers T/A...
