The myth of the "Easy Remove Deck".
   / The myth of the "Easy Remove Deck". #11
Trust us...it gets easier the more times you do it. Sometimes with new equipment it's best to do it by the book.
Given the grass conditions earlier this year I've become all too familiar with the procedure. After 2 deck belts and 1 PTO belt I can't start the process without the ritual profanity.
   / The myth of the "Easy Remove Deck". #12
I thought the same until I tried and worked on the deck. Now they move with ease. I'm sure you have sprayed them with WD40 or something, take one hand and lift the deck a bit, almost jiggling it while you pull on the small handle attached to the clips. The weight of the deck keeps the tension too high to pull open the springs. I wear gloves to get a better grip when doing that.
The real "MF" is the belt tension spring. Comes off easy, getting it back on takes arm strength that my old back can't support. Always seems to take me 30 minutes and a lot of sweat and curse words. Good luck.
Oops, just saw a bunch of the same advice. Sorry, late night insomnia from back pains, didn't wait for the whole thread to pop up. All sage advice here, especially about lowering deck, putting it on concrete. I for one never have "giggled" while working on these God forsaken Cub Cadets. Will not own another.
   / The myth of the "Easy Remove Deck". #13
The deck on my RZT54 has the same J bolts. The deck comes out pretty easily. I changed the blades this year with the deck still on as well. I rode the front end up on my Rhino Ramps and used a short piece of 2x4 to hold each blade while I removed them. This procedure worked out pretty well for me. I personally prefer this method over removing the entire deck.
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
TANK MANIFOLD (A58214)
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
2004 GMC Sierra 3500 Utility Flatbed Truck (A60460)
2004 GMC Sierra...
