The Log house Project begins........
   / The Log house Project begins........
And then the rains came..............but it does bring out the color of the cedar:
We went up to check on the floor. So far it is handling the water ok, but I am a little worried about what it will do when it drys back out. We are going to get over 48hrs of straight rain from this tropical depression.
I hope to get the walls completly done by the end of this week.
   / The Log house Project begins........ #305
Have you thought about using a urethane to make the beautiful colors last?
Yep, but that will be after the entire interior walls get sanded with 40/60 grit. The outside will get pressure washed, then coated with a UV resistant sealer.
   / The Log house Project begins........ #307
We used a squeegee to get the water off our sub floors when it rained during our construction and we even bored a few holes in the sub floors for drains...We kept up with it ...over and over until the rains stopped...Sure glad we did too...We used 3/4 inch T&G Advantac...good luck !
   / The Log house Project begins........ #308
Can you tarp it? They make some pretty big ones....I've seen em at HF. I hate water on open wood, always tried to avoid it if at all possible.
Brin, it's been raining for 24hrs straight and not supposed to let up until tomorrow...a squeegee would not help much. This is 3/4" T&G Advantage, water resistant, w/lifetime warranty. My neighbor is a builder and said that he has had an open floor to weather for up to 4 months with no real ill effect.....man I hope he is right.
Scout I'm with you, but my big tarp went south covering hay last year. If I can get thru this I hope to get the rafters up within two weeks.
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
DYNAPAC CC5200VI DBL DRUM ROLLER (A52707)
DYNAPAC CC5200VI...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
BOX BLADE (A55745)
BOX BLADE (A55745)
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
