The Little Tractor that DID
   / The Little Tractor that DID
All the rocks are below the black humus. We have plenty so keep yours. Below in this area is glacial till. I swear the rocks breed faster than mice. The "rings" are where I attach my hitch receiver attachment using a long 5/8 hitch pin. I also spaced the teeth so I could attach my clamp on forks w/o removing the tooth bar. One space is perfect for 40 X 48 pallets.
Ron
   / The Little Tractor that DID #12
Hey Ron,
Can I get some pics of that job you did on the bucket, no point me reinventing the wheel if I want to do something similar down the track, and from the little bit I can see, it sure looks like a nice job!
Hey Ron,
Here you are: DSCN1242.jpgDSCN1243.jpgDSCN1244.jpgDSCN1245.jpg
Sorry it took so long. Note I spaced the teeth so I can install my bucket forks between. I have four forks I use for brush handling
Ron
   / The Little Tractor that DID #14
Hey Ron, you are out stumping me! Great work. I see you have a 12in on your BH so maybe you won't miss your 8in if I borrow it for a bit?
Come and get it. I probably will not need it till next spring. Dig those ditches so they are self draining. I did some trenches last winter and the water just percolated away.
Ron
   / The Little Tractor that DID #16
Here you are...........
Ron
Thanks for that, now you have me thinking about some forks!
So did you make the tooth bar complete, is that small crack on the end a crack in the root between 2 pieces of flat bar?
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2022 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2022 JCB HM180T...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
1981 Chevrolet P30 Box Truck (A50860)
1981 Chevrolet P30...
