The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #1,101
The 2815 (with the additional wing) is no finish mower, but I haven't noticed a lot of really uneven distribution of grass. Mine is set up with blade ring steel guards underneath and protective chains all around. Which should even add to disruption of airflow. Any chance you might be allowing PTO speed to get too low to spread the cuttings? Hard not to back off the throttle when in a ditch though...
I run hard against the engine RPM to PTO recommended 540 speed. I don't use "Econo" PTO at all frankly.
If I remember correctly two of my gearboxes turn in one direction and the third gearbox in the opposite direction. Have no idea if that could affect your situation though...
You have a unit that a dealer may not sell that many of, so they may not be of great help. I've just gone straight to the mothership in Selma and talked to their engineers before. Seemed knowledgeable and were reasonably helpful.
Your machine should be a strong unit - I have been satisfied with my older 2615 as well as my 2815. We don't baby equipment - we use it.
Good Luck
I have the rings and chains. The blades do opposite directions. I run it in 540e at about 560 rpm most of the time. It gets run hard and will chew anything or spit it out. As I remow the clumps it just moves it behind the main blade. It looks like a windrow ready to be bailed. The dealer sold maybe one, so he is no help. I have been meaning to call Selma ( was there today) about making it a 2815. I bet that will cost as much as a new one.
Had a friend go by the factory in Selma for a part for a very old bush hog that there were no parts for. He made the part and wouldn't take any money.
My clippings from my CX-15 are evenly spread. Have stump jumper pans and deck rings.
   / The Life of a Custom Mowing contractor #1,103
Mine could be “We mow steep, but our prices aren’t”
I like that!
But I'm sure you are like the guy in our town, where it's more about his good reputation and good equipment then it is about price.
You might be too modest to say that, so I said it for you.
   / The Life of a Custom Mowing contractor #1,104
Question HD: Why are bale that I am positive were baled dry now testing wet when they have been sitting out all summer?
Are they stored inside or outside?
How lomg ago were they baled?
So we finished 2nd cutting and are now trying to catch up on some contract mowing projects.
Backing down between an old fence line and the abandoned, raised RR berm on the right.
Here we are mowing some very soft ground near a stream. You can see one of my guys weed wacking fence in the background. I cut in reverse on soft ground so I can observe if my CX-15 tires start to track mud, it’s time to pull forward.
Finished. Well this part, anyway.
Looking nice from the road.
Weed wacked all this fence along road myself. You can see my Ram off in the distance.
Bowhunting anyone? Man the back of my truck’s a mess.
   / The Life of a Custom Mowing contractor #1,107
They are stored outside and have been baled for 4 months. They are actually not mine bales they are a friends.
That could be your answer if enough rain has entered the bales.
If rain has not entered the bales it could be something as simple as the moisture tester having an issue, or not testing in the exact same spots.
What I usually see is an increase in moisture readings for the first weeks while the bales sweat/heat, then decreasing bale temps.
Ask your friend to take readings of bale temps. If they are hot (like over 100+) then they must have been baled more damp/green than originally thought. Did your friend do a “twist test” on the hay right before he baled it?
   / The Life of a Custom Mowing contractor #1,109
I see your tag is dryland farmer, depending upon the ground conditions it is quite possible for bales to wick moisture up from the ground. Are they small squares, big squares, rounds and how are they stacked.
   / The Life of a Custom Mowing contractor #1,110
Round bales stacked in rows of two that are right against each other. Not the way I would stack bales but he has a self-loading wagon that stacks them that way.
2012 KIA Optima Sedan (A56859)
2012 KIA Optima...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59575)
2018 INTERNATIONAL...
