The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor
15 acres in one hour is impressive!!!!! How fast are you going? In my tractor, just mowing with the batwing, I'm uncomfortable when I'm going faster then 3 mph!!!!
Probably about 7MPH. My passes are about 20-21’ wide.
A disc mower cuts a lot faster & cleaner than a rotary
   / The Life of a Custom Mowing contractor #842
I'm laughing because I never would of thought of 7mph as being way too fast for me. But I know that there is no way in the world that I would ever try to mow at such a crazy high speed!!!!!!
Thats probably higher than average because I slow down around trees, poles, etc.
   / The Life of a Custom Mowing contractor #844
Here’s some scenes from today.
It’s been so dry, the radiators are clogging up with hay chaff. Spent a few hours flooding the radiators until they were flowing clean.
Headed over to cut some pretty rough flood plain that actually makes some nice hay. This is Reeds Canary grass.
Here we are after a few swipes
Heres a look at the 302 on the side
Even with lots of poles, I was able to get this little 15 acre field cut in a little over an hour.
When we exit the field, we have to cross over East Penn’s RR tracks
Down the road and back to the shop
Back at the farm & parked for the day
Hay Dude, I've got to ask a quick question. You said "radiators are clogging up with hay chaff. Spent a few hours flooding the radiators until they were flowing clean." Did you actually use water to flood them clean? I ask because although I've got the Genie set, I've only ever used the air portion to blow out the fins.
I'm kind of afraid that if I use the water portion I'll end up with mud caked fins and a much bigger problem. So how does the water flood seem to work? In your opinion, as well as - or better - than the air portion? It sounded as if it does take quite a bit of time, but if it works better I'm willing to try it.
Thanks for your opinion. Greg
   / The Life of a Custom Mowing contractor #845
I use a varsal gun for cleaning radiators. You can get them cheap at Princess Auto or Harbor Freight. If you use water instead of varsal it works really well. The water softens up the dirt and the air blows it away. I then run the tractor etc. for a few minutes to dry everything off and you can go back to work.
   / The Life of a Custom Mowing contractor #846
I've been of the same opinion as Greg. I've always thought using water would make things worse, but I've never tried it, either.
Looking forward to more info from HD about this when he gets a chance. Maybe I need to change up how I do things.
   / The Life of a Custom Mowing contractor #847
Can you provide links and/or more info on these? I've never heard of a "varsal gun"?
   / The Life of a Custom Mowing contractor #848
Me either, Eddie. Not sure which would break first, the machine or me.
Lol.
   / The Life of a Custom Mowing contractor #849
The Discbine style of mowers can handle quite high speeds they are often advertised as being capable of mowing and conditioning hay at 10 mph. The larger frame 4wd tractors with good sized tires can handle 6 to 8 mph in most hay fields and in a real smooth one 10 mph is doable but the same hp tractor in a 2wd model with the much smaller front tires is often too rough. Between the tall tires and the air suspension seats the ride can be quite comfortable , the head lands are often rougher and merit slowing down for.
Fields that I have mowed at 6-8 mph in an IH Magnum, I can only do 4-6 mph with a tedder or rake in a smaller tractor such as my Branson 8050.
Then a couple of places around here have the Krone Big M mowers with 30+ ft of swath width and 400-500+ hp, these things are flying down fields at 10+ mph. And a price tag of half a million dollars.
USED 10000 LB TORSION AXLE (A57192)
USED 10000 LB...
2008 Ford F-450 Crew Cab Service Truck (A55973)
2008 Ford F-450...
UNUSED FUTURE 36C STAD ON SKID STEER (A57192)
UNUSED FUTURE 36C...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
