The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #1,861
I'd like to know what word in this post generated such a response;
   / The Life of a Custom Mowing contractor #1,862
I didn't know about ATF on hard packed grease. I remove the zirk, dig out as much as I can with something tiny that I find laying around, and they spray inside there with Brake Fluid. That seems to dissolve what's in there. Then I put on a brand new zirk fitting and pump full of grease until I see it coming out.
My post is also waiting for a moderator to approve what I wrote, and it will remain invisible until then.
   / The Life of a Custom Mowing contractor #1,864
Lou and Eddie, You both used ATF (Automatic Transmission Fluid) in your posts and I believe that's the reason you got hidden? AI must be being used to scan posts and it doesn't recognize the acronym.
   / The Life of a Custom Mowing contractor #1,865
Al co haul, Too back go and Fyre alms...(This is a test, only a test...)
   / The Life of a Custom Mowing contractor #1,866
Whatever the reason, it is complete stupidity.
Even if it was thinking of the alcohol, some kind of arms and tobacco why in the he double hockey sticks would it block that. It is a government bureaucracy that should be outlawed even though it's not, and has definitely exceeded it's legal authority many times.
   / The Life of a Custom Mowing contractor #1,867
Nope that abbreviation for that overbearing bureaucracy didn't fly again. This blocker is just about as over bearing and stupid as that damned bureaucracy.
This place has gone pillow soft.
Back to some Field Mowing. With hay baling finished, I suddenly don’t feel as stressed out
Still can’t understand why the new phone won’t post pics.
   / The Life of a Custom Mowing contractor #1,870
First picture is 12 Mb May be too big?
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
BOMAG BW213 SMOOTH DRUM ROLLER (A58216)
BOMAG BW213 SMOOTH...
John Deere 6619 Power Unit (A57149)
John Deere 6619...
2601 (A59228)
2601 (A59228)
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
