The Jerry Can Conundrum
   / The Jerry Can Conundrum #1
oercheron
Bronze Member
Aldergrove, BC
2 Kioti, 2 John Deere. None wore out yet but the '49 ain't used that much anymore
Things that make it hard to get up in the morning:
-Knowing that all 8 Jerry cans full of fuel are at the FRONT of the pickup box and INSIDE the canopy. Ahead of a full pallet of sacked cement with grease guns, chainsaws, and several shovels & rakes on each side. And a fully-loaded trailer that won't let you lower the tailgate because the jack is in the way.
-Having to fill a machine that takes 2 or more Jerry cans to fill
-Having to fill a machine that takes slightly LESS than 1 Jerry can to fill
-Having to unload 8 Jerry cans from the pickup and carry them to a spot you can't back up to
-Not having enough Yellow cans for the diesel and/or Red cans for the gas
-Also having mixed gas in one of the red or yellow cans. But not labeled.
-"Green" jerry cans
Here is how I fixed part of the problem for hardly any $ - Diesel transfer tank - YouTube
   / The Jerry Can Conundrum #2
I'm sure that meet all applicable codes (tongue in cheek) :) But it works and that's what counts.
   / The Jerry Can Conundrum #3
Skid tank in Ontario must be bolted to the bed they are carried on (bolted to the trailer/pickup bed). The goobermint changed the ruling 2 years ago. :(
Still OK in BC for this size container. Ratchet straps will meet requirements.
   / The Jerry Can Conundrum #5
When I got tired of screwing around with Jerry cans I started using an electric fuel pump. Have a hose that goes in the can, and a hose that goes to whatever is getting fueled. Plug it in and it starts pumping. Far easier and a little bit faster than if I did it manually.
   / The Jerry Can Conundrum #6
That's what I am currently doing, hoping to build a fuel trailer soon though. The little HF diesel pump empties a 5 gallon in short order! It's certainly a billion times better than holding up the cans though.
T/A Trailer Axles (A51692)
T/A Trailer Axles...
2012 CATERPILLAR 308E CR EXCAVATOR (A51246)
2012 CATERPILLAR...
UNUSED INDUSTRIAS AMERICA 10F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
5" & 6" CHANNEL IRON UP TO 20' LONG (A51247)
5" & 6" CHANNEL...
