The JD Cut Wheel Spacer Answer Thread
   / The JD Cut Wheel Spacer Answer Thread #1
Dutch445
Elite Member
Upstate NY
JD X585
OK, after fielding questions and researching different ideas, I stumbled across
a solution to a question that gets asked countless times,
where do I get wheel spacers for my JD Cut (3020-4020)
tractor?
After seeing the Unverferth spacers, along with some other styles,
I came across this kit from Grouser and we just installed them on
a 3120. The kit part # is 808020 (8"X8" hole patter, 2" thick) and
they are part of skid steer track parts when spacers are needed.
They fit the 3020 hub perfectly, we stacked 2 for 4", using loc-tite
on the buried hardware. The spacers come with studs and chamfered
nuts, and the original wheel bolts worked to bolt the first spacer
to the hub.
total cost, $400 plus freight, for a set of 4 2" spacers.
Check out their pdf for more info. They come as a set of 4
since they are for skid steers.
:D
  • Wheel Spacer Parts.pdf
   / The JD Cut Wheel Spacer Answer Thread #2
:D
Awesome :thumbsup:...I've been eyeing the S/S Spacers for a while...been looking at measurements, etc..and while It appeared it would work, I didnt want to take a gamble. Thank You Very much for takin the plunge and letting us know about it!
If anybody wants to split a set, PM me...I've got a newborn due any day now so I wont have time to do the shopping & legwork, but I'd pay my share plus S&H....
   / The JD Cut Wheel Spacer Answer Thread #3
you can get them on ebay for around $300 shipped.
   / The JD Cut Wheel Spacer Answer Thread #4
Just double checking.
This is the '60's model 3020?
You said Cut 3020 and wondered if you are talking the 3x20 series.
   / The JD Cut Wheel Spacer Answer Thread #5
Will they work on a 2010 4720?
JD Cut (compact utility tractor) 3120-3720 etc, and 4120-4720
also, any prior models with 8 bolt rims I would imagine..
   / The JD Cut Wheel Spacer Answer Thread #7
FYI to anyone interested... I just PM'ed everythingattachments.com as they are both a Grouser dealer AND a TBN site sponsor with a link to this thread...hopefully they can shed more light (Pricing & Availability) on this.
   / The JD Cut Wheel Spacer Answer Thread #8
I've been using SS wheel spacers for a Bobcat (2") on my JD110 TLB for 2 years now - with no problems, whatsoever.
I have less than $300 invested ($267). The wheel size and lug spacing on my 110 appears to be identical to the 4000 series machines and the 110 is probably 3,000lbs heavier.
The Unverferth's were nearly $900!!! :eek:
AKfish
   / The JD Cut Wheel Spacer Answer Thread #9
He probably should have wrote 3x20 and 4x20;), but I am sure you knew that:thumbsup:
   / The JD Cut Wheel Spacer Answer Thread #10
Just to make sure. I have a JD 3720 cab and was looking at the unverferth 6 inch spacers. They don't offer the 4" like they once did. I have the smaller R4 tires so will these spacers work better (4") than the 6" unverferth spacers? I want to get the machine a little more stable.
thanks
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A53843)
2021 QUALITY...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
4 ft Plastic Feeder Trough (A53117)
4 ft Plastic...
