The JD Cut Wheel Spacer Answer Thread
   / The JD Cut Wheel Spacer Answer Thread #91
Still absolutely sold on these spacers. Have not had to re-torque anything. Still enjoying the stability. Have done a ton of loader and backhoe work with it since installing, no issue. If this was primarily a field tractor, pulling an implement through the ground, I probably would not feel as comfortable with spacers.
   / The JD Cut Wheel Spacer Answer Thread #92
Thank you for the reply and comments. Looking forward to getting mine on soon. Take care!
   / The JD Cut Wheel Spacer Answer Thread #93
I've been using SS wheel spacers for a Bobcat (2") on my JD110 TLB for 2 years now - with no problems, whatsoever.
AKfish
That would make the rear track wider than the bucket, correct? any issues?
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
INSPECTION (A57454)
INSPECTION (A57454)
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2 POLY PIPE (A58216)
3-5TH WHEEL PLATES (A58216)
3-5TH WHEEL PLATES...
UNUSED INDUSTRIAS AMERICA EASY MAN TREE & POST (A58376)
UNUSED INDUSTRIAS...
