The First Beast is Complete..Serious BoxBlade!!
   / The First Beast is Complete..Serious BoxBlade!!
We still haven't had a chance to do a video, but here are some pics of a 10' model that is headed to Wyoming.
This thing weighed 2,300 pounds before the 10 shanks were installed.....which means the total weight will be over 2,600 pounds.:shocked:
Travis
And here it is ready for the truck!
   / The First Beast is Complete..Serious BoxBlade!! #63
HOLY--MOLY....
"Beast" is about the right term....
Which coal mine it it going to ??
Looks nice...
   / The First Beast is Complete..Serious BoxBlade!! #64
Why are the two outside teeth tilted out some? Is there some kind of secret there?
   / The First Beast is Complete..Serious BoxBlade!! #65
   / The First Beast is Complete..Serious BoxBlade!! #66
Is that a Cat1/Cat2 or Cat2/Cat3 setup? because that seems awful big for a category 1 tractor.
At 2600lbs, I'm not sure how many cat 1 tractors could even pick it up. :eek: I have a cat 2-12,000lb tractor with a 5500lb lift capacity and I know that I would not want anything to do with it. I'm sure that there are other cat 2 tractors that could handle it fine, but I imagine that it is a cat 2-3 hitch. ;)
   / The First Beast is Complete..Serious BoxBlade!! #67
I think that is just from the curvature of the camera lens.
   / The First Beast is Complete..Serious BoxBlade!! #68
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=351083"/>
What are they using to pull that bad boy with, do you know?
   / The First Beast is Complete..Serious BoxBlade!! #69
My cat 1 tractor will lift just a shade over 2400 lbs.. I bet it wouldn't even pick it up.. Of if if did the nose would be in the air!
   / The First Beast is Complete..Serious BoxBlade!! #70
I am pretty sure that it was mentioned that they put the 2 outside teeth at an angle on purpose to be able to rip closer to the edges. My question is why are not the teeth spaced evenly apart? :confused3:
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
