The First Beast is Complete..Serious BoxBlade!!
   / The First Beast is Complete..Serious BoxBlade!! #41
How much does the 78" model weigh?
We don't have true weights on any sizes other than the 96", but the 78" should be 1,800 pounds+.
If you buy one, we'll build and weigh it for ya!!
Our engineer can probably narrow it down, if you want a better estimate.
   / The First Beast is Complete..Serious BoxBlade!! #43
We don't have true weights on any sizes other than the 96", but the 78" should be 1,800 pounds+. If you buy one, we'll build and weigh it for ya!! Our engineer can probably narrow it down, if you want a better estimate.
That's okay, no need to go through the troubles but thank you for the rough idea, and the offer to get a more detailed weight. It sounds like an excellent weight for that size. Once they are available with a hinged rear blade and hydraulic scarifiers I may think a little more about it.
You know what they say about hydraulics....once you go hydraulic you NEVER go back. :)
   / The First Beast is Complete..Serious BoxBlade!! #44
Bump - where's the action pics? :)
   / The First Beast is Complete..Serious BoxBlade!! #46
I took these while I was at everything attachments the other day.
   / The First Beast is Complete..Serious BoxBlade!! #48
So has this thing actually seen some use or what?
2015 MACK GU713 (A50854)
2015 MACK GU713...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
Ram 4x4 Pickup Truck Bed (A49461)
Ram 4x4 Pickup...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
