THE DEAL IS DONE
   / THE DEAL IS DONE #21
Really nice rig you're getting! Congrats!
I suggest taking enough time with your dealer for them to explain all features and put you through the motions of the backhoe too. When you disconnect the rear hoses to remove the backhoe, have them make up a short piece of hydraulic hose to allow you to loop it between the unused rear remote circuit so you can't deadhead the circuit if you accidentally engage it when disconnected from the tractor.
While checking for loose bolts check the entire structure of the FEL where it attaches to the frame- all bolts both sides. Keep checking until they are tight every time you check them. Check all zerks to make sure they were greased. There's lots of them on the machine and hoe.
Enjoy it and keep it reved high enough to allow the regen to work as designed, minimum 1800- 2,500 for basic loader work, or higher as needed.
Enjoy! Ask questions here.....
   / THE DEAL IS DONE
Thanks for the support and kind words!
   / THE DEAL IS DONE
Congrats you have a great tractor. :thumbsup:
Even though your rears are loaded you will find you can easily lift the rears off the ground with the loader strength/capacity. If you are leaving the BH on all the time it will not be a problem. Otherwise you might want to get a ballast block.
Thanks Lynn...how long have you had yours? How do you like the power shuttle?
   / THE DEAL IS DONE #24
I've had it a little over 4 years. The PS is great for field work, but FEL work not so great. Overall it's a great tractor. I always look for things that need to be done using the tractor.:laughing: Sounds like I'm joking, but I'm not.:D
This is what my ballast looks like.
   / THE DEAL IS DONE
Nice! I will probably always have an implement on the back... another question (thanks for your patience). What is your top speed to use the shuttle without the clutch or slowing yourself down?
   / THE DEAL IS DONE #26
I have used the shuttle shift in all three ranges. I was told it didn't matter, however, usually I will not reverse direction over medium range 2nd gear. I just feel better about it.:)
   / THE DEAL IS DONE
Thanks for the reply...we think alike! ;-)
   / THE DEAL IS DONE
Well- it痴 finally ready and I知 picking it up in the morning (Saturday). They had to order the 3rd remote after everything else was installed because they had the wrong one. No big deal- just a slight delay. Pics will be forthcoming soon. Excited!
   / THE DEAL IS DONE #29
Congratulations, that's a very beautiful and good tractor, good luck with it
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
INSPECTION (A51572)
INSPECTION (A51572)
2007 Toyota Corolla Sedan (A50324)
2007 Toyota...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
