Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,663
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Really nice rig you're getting! Congrats!
I suggest taking enough time with your dealer for them to explain all features and put you through the motions of the backhoe too. When you disconnect the rear hoses to remove the backhoe, have them make up a short piece of hydraulic hose to allow you to loop it between the unused rear remote circuit so you can't deadhead the circuit if you accidentally engage it when disconnected from the tractor.
While checking for loose bolts check the entire structure of the FEL where it attaches to the frame- all bolts both sides. Keep checking until they are tight every time you check them. Check all zerks to make sure they were greased. There's lots of them on the machine and hoe.
Enjoy it and keep it reved high enough to allow the regen to work as designed, minimum 1800- 2,500 for basic loader work, or higher as needed.
Enjoy! Ask questions here.....
