The brush cutter!
/ The brush cutter! #1
RFoutthere
TYM T264HST
Bought a replacement stump jumper for my brush cutter but the bolt holes for the blade bolts are about 1.185” (approx. 1+3/16”). I can’t use standard blade bolts because they’re 1+1/8”. They are loose in the bolt holes on the stump jumper and won’t engage the key way slot. Does anyone know where Ican get blade bolts that are oversized? Even if they are 1+1/4” I can put them on the lathe and turn them down. Any help is appreciated.
I’m out!
/ The brush cutter! #2
Is the jumper the same brand as the mower?
Run an internet search for "1.185" stump jumper bolts for rotary cutter". I got a lot of results.
/ The brush cutter!
Thanks RayIN. The new jumper is generic. Took a while to find one with straight splines. I’ll try searching the bolts that way and hopefully get some in here. If I don’t find them I think I may have found a work around.
Thanks again
RFoutthere
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2025 Rake Mini Excavator Attachment (A66734)
2025 Rake Mini...
2016 Ford F-150 Extended Cab Pickup Truck (A64557)
2016 Ford F-150...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
2013 CHEVROLET 2500 HD (INOPERABLE) (A67714)
2013 CHEVROLET...
