The brush cutter!
/ The brush cutter! #1
RFoutthere
TYM T264HST
Bought a replacement stump jumper for my brush cutter but the bolt holes for the blade bolts are about 1.185” (approx. 1+3/16”). I can’t use standard blade bolts because they’re 1+1/8”. They are loose in the bolt holes on the stump jumper and won’t engage the key way slot. Does anyone know where Ican get blade bolts that are oversized? Even if they are 1+1/4” I can put them on the lathe and turn them down. Any help is appreciated.
I’m out!
/ The brush cutter! #2
Is the jumper the same brand as the mower?
Run an internet search for "1.185" stump jumper bolts for rotary cutter". I got a lot of results.
/ The brush cutter!
Thanks RayIN. The new jumper is generic. Took a while to find one with straight splines. I’ll try searching the bolts that way and hopefully get some in here. If I don’t find them I think I may have found a work around.
Thanks again
RFoutthere
HURRICANE (10) DRAWER (A64280)
HURRICANE (10)...
2021 Chevrolet Malibu Sedan (A61574)
2021 Chevrolet...
John Deere 6200 Tractor (A64047)
John Deere 6200...
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
