The B7800 that thinks it can...
   / The B7800 that thinks it can... #1
avorancher
Deluz, CA
Kubota B7800, RTV900
Today, I hired a company to do some heavy-duty chipping at the top of my property. They showed up with a 6000 lb. chipper on the back of a Chevy Silverado. There are 3 rather steep inclines on the dirt road to get there, and it rained a couple days ago making things slick. Sure enough, the Silverado lost traction on the first minor hill and just sat there spinning all 4. I had my B7800 nearby and hooked up a chain and pulled in up to a level spot.
On the 2nd steeper hill, a similar situation. When I pulled in front with the tractor, they had their doubts this time (quite a mismatch in size). Well, the little orange beast met the challenge and I pulled the truck and chipper for about 200 ft. before they could manage on their own. After that pull, they all complimented me on the tractor and were rather surprised that it had that much pulling power.
The last hill was the real test. It is a long slope with a 90 degree turn going uphill. With a running start, they got around the turn, slowed, then started sliding backwards. As they slid backwards towards the turn, they got just enough traction to stop the slide. The driver was a bit pale... another 20 ft. and there was about a 300 ft. drop off the side of the hill. The driver had to stay in the truck and stand on the brakes to keep it from sliding until we got the chipper wheels chucked. A real scary situation.
They thought my tractor was too small to help this time, so the called for another 4wd truck. A Nissan showed up and they chained it to the front. Now both pickups were spinning... not moving an inch. They loaded up both beds with wood for traction... still no go.
I ran and got the tractor as the last resort, chained it to the Nissan and pulled the Nissan, the Silverado, and the chipper up the hill. I wish I had a picture of that one. (12 wheel drive)
I'm not saying that I had more power than either of the pickups, but today there are a bunch of people shaking their heads in disbelief at the little orange tractor that thinks it can.
   / The B7800 that thinks it can... #2
Great story, a picture would have been awesome.
   / The B7800 that thinks it can... #4
That is a great story, I am glad thinks worked out. Given the problems they were having they shouldn't even have tried that third hill, think of the damage that could have been done if they slid off, yikes!
There was a couple other threads in the past that were similar, little tractors dragging trucks and trailers around after they get stuck.
/forums/images/graemlins/cool.gif
The tractions that these tractors have is pretty amazing, I have a Kubota L2350 with the r1 ag tires on it. I have had several times when our 4wd Dodge 3/4 truck wasn't able to back a trailer full ( 3 tons probably ) of hay up to our barn due to the ground being just a bit muddy. I just dropped the trailer where it was, put my 3ph trailer mover on the tractor and picked up the trailer and moved it without any tire spinning or problem at all.
   / The B7800 that thinks it can... #5
Sounds like the tractor that knows it can /forums/images/graemlins/grin.gif The big thing is that the tractor is true 4 wheel drive as opposed to the trucks that usually drive 1 front wheel and 1 back unless they have lockers which is not typical. On the tractor you have that handy axle lock pedal.... gotta love that pedal. I'd love to see pics of that train though.
Wish I had a picture too, but at the time taking a picture was far from my mind. If I had one, I could sell it to a farm safety class to use it as an example of what not to do.
I had it in low range, some weight in the FEL, the diff lock pedal depressed, and the seatbelt unhooked just in case I had to bail out if the chipper went over the edge. /forums/images/graemlins/crazy.gif
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2008 Suzuki XL7 SUV (A50324)
2008 Suzuki XL7...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
Stump Bucket (A50322)
