Piston
Elite Member
The age old.."what's the best land clearing technique" question again
You mentioned DIY, so that rules out the mulcher if you want to do it yourself. I do agree that a mulcher would be quickest, but also costly.
If you want some seat time, do it yourself. You have a full sized backhoe that will do ALL of that work. If you have a thumb, your in even better shape.
Here is my recommendation, based on clearing just over an acre of very thick, and more larger trees, with similar equipment.
Invest in a FEL grapple for your tractor, ditch the bucket, it's useless. This will cut your time in half.
Then go through and either now down, or just knock over roots and all, everything you can. Start working and making a central pile, and dump all the brush in that pile. So much fun, and so easy. You'll need some weight on the back of that tractor as well.
Then anything leftover or too big for the tractor, use the 410.
I have a Kubota L4610, and a 2wd JD 410B. I cleared over an acre of thick forest this way, and it took me 3 days.
I never once used the 410 by the way. The tractor with grapple is so much more efficient.
See here for plenty of pics of my clearing project. http://www.forestryforum.com/board/index.php?topic=61752.0
