That gear reduction starter
/ That gear reduction starter #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
My YM2310 needed another new solenoid. The last solenoid started to fail within 6 months. For about 1.5 times the cost I bought a gear reduction starter. On the advice of bmaverick I bought a gear reduction starter. That starter spins the engine much faster than the stock starter. I love it.
Eric
/ That gear reduction starter #2
Eric
I wasn't trying to hood-wink you by saying it spins and starts better, cause . . . it does. :giggle:
The starters are rated by power used to spin.
So much is lost in the old coil style as the output is robbed.
With the OSGR, most of the power goes to the output to spin.
The next winter, try starting without the thermo-start in the very cold. It will start just fine as the OSGR spins faster allowing the compression to take hold readily.
/ That gear reduction starter #3
Cold weather is the key. It's super cold it's going to be super slow. On my cold starts I always counts how long it takes for the oil light to go out. And release the Decompression lever. In Ga. in 4Sec. warm 6cold weather. Have to honestly say I only started it in 30deg. weather once or twice. No Thermal either. I have it and it does work. No need for it. The ford gas is what that comes in handy for. Warm or cold so I keep the best of both worlds. Both simple easy to work on.
2023 Dodge Durango SUV (A59231)
2023 Dodge Durango...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Ram 1500 4x4...
