Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!!
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #21
Dick,
Your correct about water flow....many Winston cup and Bush National cars (NASCAR) run with restrictor washers in the thermostat housing instead of a thermostat. Between "5/8 and "3/4 holes in the plate to restrict flow - slow down the water flow and provide time for the heads, block and radiator to cool. The faster the flow of coolant, the less time for heat exchange to occur.
This is not a new science as people have been doing it for years. As far as the above problem I would concentrate on hoses that may collapse, trash and rust in the block, waterpump impeller wobble... or anything that is restricting the flow of coolant. It would seem any temp gauge that's at 3/4 is too hot.
Mark
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #22
Yes Mark that is another good idea about the hoses collapsing. I've had that happen, they will go just as flat as a pancake, if they have gotten kind of soft. Of course then the water won't flow at all either, so that could be happening also. Its really hard to tell, when one isn't there to see.
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #23
"The faster the flow of coolant, the less time for heat exchange to occur."
I believe that an engine might run hotter without a thermostat, but not because there is less time for heat exchange to occur. If an engine runs for a half hour, isn't coolant passing through the head(s), block and radiator for 30 minutes regardless of the presence of a thermostat? To put it another way, isn't there cooling water in the head all the time that the engine is running, so heat exchange is occurring all the time, regardless of water speed? My guess is that a restriction in the thermostat housing causes the water in the block/head to be under slightly higher pressure and therefore minimizes development of a steam layer at hot spots along the wall of the water jacket. Without the steam layer the water makes better contact with the metal and heat exchange is more efficient, and therefore the engine runs cooler.
Maybe this is the right reason and maybe it isn't, but 30 minutes of water contact is still a half hour. /forums/images/graemlins/smirk.gif
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #24
What the crud are u talking about?
Yes, closed: no water can get through. Open: water gets through.
What is to think about?
His thermostat being stuck open is not causing his tractor to overheat period. Might be stuck closed but not open.
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #25
I sure wish you were right. For is you were, notice I said were. Then my YM 1700 that doesn't have a water pump would run just as cool as one with a water pump. But it just don't happen. This has been figured out a long time ago, so why do you think you have a new answer, better than the people that have been working with it for many years. Some times by slowing something up it can pick up more, is that hard to understand?? And again its like the fan cools the radiator because more air is going through it, air is going through it anyway, but in this case more air cools it more. Now I didn't figure that out, it has already been done, and I accept that, and it works.
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #26
Yes in case you havn't noticed this forum is not to find fault, just read what I said. He said he ran a water hose into the tractor hose, and the water flowed right in. I said if it were stuck closed the water would not flow into it, as it would stop it. If it were stuck open then the water would flow through it, as it wouldn't be stoped by the thermotat. That is what I said you needed to think about. /forums/images/graemlins/smile.gif
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #27
Yes, they do that but not why you said. They don't want them running to cold. But they don't want to risk all on a thermostat either. I just disagree with the science. I can see where units with water pumps may need a thermostat to get the water to circulate but we are not talking about water moving to fast to pick up the heat. I am calling that junk science...Good luck proving me wrong!!!
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #28
</font><font color="blue" class="small">( At 3/4 its still hot and the fluid is boiling in the overflow. )</font>
A bad headgasket will cause bubbles in the overflow.
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #29
Yea, I read that but I am not there to see if water is really going through the block or not. Also some thermostats never close completley....I don't mean to give you a hard time I just don't buy the water moving to fast science.
/ Thanks to all!!!!!!!!!!!!!!!!!!!!!!!!!! #30
I would have to think about the steam part but you are making sense about the 30 minutes of transfer regardless part.....
I agree with this!
2008 FORD F-550 SUPER DUTY (A60736)
2008 FORD F-550...
2018 FORREST RIVER WILDCAT BUMPER PULL (A60736)
2018 FORREST RIVER...
2000 GMC C7500 (A60736)
2000 GMC C7500...
Forklift (A56857)
Forklift (A56857)
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
