Thanks Fitrite Hydraulics!
   / Thanks Fitrite Hydraulics! #1
Helitech
Aberdeen, MS
5220R Branson, 1256 International
Worth the wait! This hydraulic top link far exceeded my expectations, it's a lovely piece of work. I'll let the pictures do all the talking.
   / Thanks Fitrite Hydraulics! #3
You will be amazed with versatility of the top link.
   / Thanks Fitrite Hydraulics! #4
You'll be equally amazed at how well a side link helps...
   / Thanks Fitrite Hydraulics! #5
I have the same top link from Fitrite for my Kubota M6040. Bought two years ago - $395.
   / Thanks Fitrite Hydraulics! #6
I hate this place.....really really really really hate it:confused2::eek::D
Brian - you should have my order in you inbox
Man I still hate this place....:shocked::cool2::thumbsup::laughing:
   / Thanks Fitrite Hydraulics! #7
I totally understand the money obstacle in tractor additions like TnT. And I would never pressure anyone to spend that money uncomfortably.
With that said, in my case, it's frequency of use is only second to 3rd function on the FEL. And that is certainly open for debate.
Congrats on the addition.
   / Thanks Fitrite Hydraulics! #8
A picture is worth a thousand words, and after seeing the install and quality and remembering how many times I have gotten on and off the tractor to fine tune. this will make things simple.
On question, and this may sound dumb. Currently when I hook up I have the tractor off and adjust the top link to the size needed as I work the top pin in. I also usually have the lower quick adjust links extended too. Once hooked up I raise the unit to get the lower extension to lock home, lower the unit and then re adjust and lock down the top link.
I'm guessing how I need to leave the tractor running to extend or shorten the top link as needed, or can it be pushed in by hand with the tractor off if it is extended? I am a little hesitant to hook up with the tractor running. I'm guessing all other adjustment will be from the seat.:thumbsup: Am I thinking correctly? Depending where I park the attachment, sometimes it is a time consuming process to get the top hooked up
Thoughts
   / Thanks Fitrite Hydraulics! #9
You might be able to extend the cylinder, leave the lever in the "float" position if you have that function, then shut the tractor off and retract the cylinder by hand?? Depending on how strong you are.
   / Thanks Fitrite Hydraulics! #10
Quick Hitch time!!!:D:thumbsup:
1974 Ford F600 Grain Truck (A56435)
1974 Ford F600...
17101 (A55851)
17101 (A55851)
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
1995 TALBERT 50 TON LOWBOY TRAILER (A58214)
1995 TALBERT 50...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
