Text size
/ Text size #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
If I show the full page, I can barely read all the text, not only because of the light blue, but the tiny print.
Is there a way in Chrome to enlarge text.
I can magnify by using Ctrl and roll the thumb wheel, but a lot of the data is off the screen.
Larger text and less on screen would be ideal for me. I still want to see full screen left to right .
Help.
/ Text size #2
Help.
I'm using Chrome here and played with the Ctrl+ThumbWheel ( same as Ctrl and +/- keys) and about all I could come up with to duplicate what it sounds like you're seeing is, maybe you have the edge (right edge?) of Chrome off the side of your screen? Meaning, you can't see the scrollbar on the right side of the browser window?
Grab the right side of the browser window and move it to the left (make narrower), then try the Ctrl+ThumbWheel.
Or, make your Chrome "Full Screen" and that'll keep it within your screen boundaries.
That help any?
/ Text size
That help any?
No, I am seeing the full page but in tiny print. I can see the right scrool bar
I remember IE had three or 4 print size.
Is there a place in Chrome that I can increase print size without magnifying the screen.
Whenever I use the CTRL and thumb wheel, I can magnify very large .
I also have a 5 button wireless mouse that has a magnify window.
I can magnify the screen, but can't see the full screen.
Thanks.
/ Text size #4
Thanks.
Try this:
Click the "wrench" icon in the upper right corner of Chrome
Settings
Show Advanced Settings (very bottom of the new settings screen)
Scroll down to "Web content"
Font size: Dropdown Menu allows you to change your fonts
That should change the fonts "on the fly" and let you see what you're getting into on the same screen.
lemme know?
/ Text size
Try this:
Settings
lemme know?
I finally found the font size and the page view looks much better.
I was hoping TBN would allow me to select my own colors for text, or is there an external way to change any text color.
Thanks.
/ Text size #7
Thanks.
If you're still having issues, if you could post a screen shot of what you're seeing, that would help. The text size should be the same as the old forum.
/ Text size
Here it is. I had to change Chrome font size.
Lots of stuff on this page is messed up.
Second screen left side.
/ Text size
All the data under the members name, is it really necessary .
Sometime it only allows one post per page.
As long as the data is available, just the basic info.
Do you need to list 20 tractors,chainsaws, and weed whackers to show ownership for each person .
All that data should be on the profile page.
A lot of the reply with quote, are used to much. Takes up space.
When I click on Forum at top. a small window comes up and ask if I want to log out.
