Texas Man, 70, killed by bee swarm while mowing
   / Texas Man, 70, killed by bee swarm while mowing #41
I just found a bald faced hornets nest right in the ground by my outside faucet. 2 of the buggers kept buzzing me, moved so fast they seemed to disappear and reappear a few feet away.
Seems they always have 2 guards on the nest.
After reading how they never nest in the ground, went back to look today and see a few going in/out right where I thought they were, in the ground.
I have seen/removed plenty of yellow jackets, these are bigger and a lot faster. Should be interesting to see how the wasp spray works. Have to go pick some up after we used up the last bit on 2 that had got in the house.
So far no stings, but where they are will certainly not work out well
   / Texas Man, 70, killed by bee swarm while mowing #42
Bar none. This is the best wasp/hornet spray I’ve ever used. If I spray a flying critter it dies in mid air.
   / Texas Man, 70, killed by bee swarm while mowing #43
You guys ever have a spray can that just dribbles out the nozzle and dies? I did and you learn to run again!
   / Texas Man, 70, killed by bee swarm while mowing #44
I HAD A PAPER NEST OVER MY GAGAGE DOOR A FEW YEARS AGO. I GOT CLOSE ENOUGH TO THROW SOME SEVEN DUST ON THE BOARD NEAR THE NEST. AN HOUR LATER THERE WAS NO ACTIVITY AND I NOCKED THE NEST DOWN. I'VE ALSO PUT SOME NEAR A GROUND BEE ENTRANCE AND IT WORKED THE SAME WAY.
If you leave that nest up, it repels other wasps.
   / Texas Man, 70, killed by bee swarm while mowing #46
What is seven dust?
   / Texas Man, 70, killed by bee swarm while mowing #49
No need to yell, may even draw the wasps in. ;)
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52141)
2015 VOLVO VNL...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
