Test
   / Test #31
Re: Edit The Thread Title
If Somebody else pointed this out than I missed it. You can delete a post for 24 hours but you cannot delete a thread which you have started, nor can you edit the title.
No doubt you have already figured that out.
I think you can edit the thread title if you started it, within 24 hours.
If no replies to a started thread and you delete your post, the thread is deleted.
You can change the thread title for only your post, as shown above.
   / Test #32
Only the admin can edit thread titles and delete threads.
As I'm sure you just found out on your own "test" thread.
   / Test #33
There is no Delete button when I click Edit, but I did edit the Thread title.
   / Test #34
Okay, I did not think a user could do either.
I know users can't delete threads.
   / Test #35
Wow, looks like it stayed at what I changed it to. On the Polaris forum that I am on it stays the original title for the subsequent posts.
I am sure that I have deleted the first post and the Thread before, but maybe it was the other forum
   / Test #36
What happens when you click Edit Post?
Yes, I am using a computer. Up until this morning I got three options when I clicked on Edit Post.
Save Go Advanced Cancel
This morning when I click Edit Post I get Save Go Advanced Delete Cancel, just like you said it would. Apparently Bird or somebody fixed the problem. --------------------------------------
I just discovered that the first post doesn't have the Delete button.
I am thinking that the post you clicked this morning was one of your later posts, since your first post was over 24 hours old and would not have an Edit button..
   / Test
I would really like to know if a user can delete a thread shortly after posting it. In my case I posted my thread in the wrong forum by mistake, realized my mistake and tried to delete it.
After reading about 10 different answers it is apparent to me that NOBODY knows the answer, including (especially) moderators. I guess this will be one of the 都ecrets of this forum. 😀😀
   / Test #38
Try creating another post in this forum and deleting it. That will let you know in about 30 seconds.
Aaron Z
   / Test #39
Users cannot delete threads. Users can push the report post button and ask to have it removed, though. That's easy enough.
   / Test #40
Checking to see which Thread Title shows up.
Edit: The original Thread Title showed up.
Auger Drill Bit (A56857)
Auger Drill Bit...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
14in Digging Tooth Bucket Excavator Attachment (A55973)
14in Digging Tooth...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
