Test Glow Plug Relay and Timer
/ Test Glow Plug Relay and Timer #1
7and2
New Holland TC29D
Sounds like a I have a possible common problem with my New Holland TC29D. When I turn the ignition switch fully to Acc/Run the glow plug light seldom if ever comes on and the tractor is slow in starting when weather gets cool thus I believe the glow plugs are not functioning. I replaced the glow plugs with no change. Other than being a "parts changer" what is the method/procedure to test the ignition switch, glow plug relay and the glow plug timer with a digital VOM? I would rather test the possible failing parts than replace all of them if not necessary.
Thank you
/ Test Glow Plug Relay and Timer #2
One at a time in no particular order and may as well check other circuits while the meter is handy.
/ Test Glow Plug Relay and Timer #3
Do you have the electrical schematic for that tractor? If yes then use the VOM to verify voltage going through the switch to the relay. Next verify relay is changing state and that voltage is being supplied to the glow plugs. Timer should time out and shut relay off.
Remove wire to glow plug and check resistance of each glow plug. They should be similar from one plug to the next.
Not sure what amperage the glow plugs draw so I would be careful trying to check amp draw with standard VOM.
/ Test Glow Plug Relay and Timer #4
Simple test to see if power is getting to glow plug buss would be to just use simple test lamp, probe to buss, clip to ground and turn switch to either glow plug position or start if test light illuminates glow plug circuit is good, if not start tracing back with probe till you find voltage, trouble will be pretty close to where you lose the voltage...Having wiring diagram will help you trace the glow plug circuit and find the problem....
/ Test Glow Plug Relay and Timer #5
I believe the power comes through the ignition circuit. Check for burnt or discolored terminals at your key switch first. Then do a visual check on all the plugs before even useing a test light.
7ft Fork Extensions (A65579)
7ft Fork...
2019 KENWORTH T880 (A65643)
2019 KENWORTH T880...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
2015 Nissan Altima Sedan (A64557)
2015 Nissan Altima...
6x6 Hunting Box Blind (A65579)
6x6 Hunting Box...
2000 INTERNATIONAL 9200 DAY CAB (INOPERABLE) (A65643)
2000 INTERNATIONAL...
