Feb 24, 2012 / Terramite t5b hydraulic fluid #1 O Oxfordcar3 New member Joined Feb 24, 2012 Messages 9 Location Oxford ct Tractor Terramite t5b I have a 1989 terramite t5b the owners manual says do not use engine oil but terramite service says use 15-40 motor oil Any help please
Feb 24, 2012 / Terramite t5b hydraulic fluid #2 J_J Super Star Member Joined Sep 6, 2003 Messages 18,973 Location JACKSONVILLE, FL Tractor Power-Trac 1445, KUBOTA B-9200HST A lot of hyd machines use motor oil as the hyd fluid. ATF is also a good hyd fluid. If service said use it, it should be OK. It is easy to come by, and just about every store carries motor oil. It might also depend on the climate where you will use the machine. Our Power-Tracs all use motor oil as the hyd fluid.
