Terramite rebuild PT 1 VIDEO
   / Terramite rebuild PT 1 VIDEO
   / Terramite rebuild PT 1 VIDEO #12
whew, I was getting worried for a minute. Don't worry it's a easy mistake to make. I did the same thing once on a snowmobile motor after a top end rebuild.. I was sweating bullets after I first checked the compression and it was way low. Then I figured out that I forgot to open the throttle during my compression test.
Part 6, getting there
   / Terramite rebuild PT 1 VIDEO #16
Glad to see you got the old girl going. Good Job! And keep us updated on your progress
Steve
here is part 9... The FEL seem to be pretty strong but the backhoe is weak, not sure what is causing it.
   / Terramite rebuild PT 1 VIDEO #18
Lifting the back of a car off the ground is pretty impressive for a TLB of it's size. I agree, I would say that the pump is working fine. The problem may be in the control block. Like you said maybe a bad bypass. A little tinkering and you should get it figured out.
Steve
Part 10... working on the pedal and new tires!!!
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
TANK MANIFOLD (A55745)
2018 Deere 323E (A53317)
2018 Deere 323E...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
UNUSED FUTURE...
