Terramite rebuild PT 1 VIDEO
   / Terramite rebuild PT 1 VIDEO
   / Terramite rebuild PT 1 VIDEO #12
whew, I was getting worried for a minute. Don't worry it's a easy mistake to make. I did the same thing once on a snowmobile motor after a top end rebuild.. I was sweating bullets after I first checked the compression and it was way low. Then I figured out that I forgot to open the throttle during my compression test.
Part 6, getting there
   / Terramite rebuild PT 1 VIDEO #16
Glad to see you got the old girl going. Good Job! And keep us updated on your progress
Steve
here is part 9... The FEL seem to be pretty strong but the backhoe is weak, not sure what is causing it.
   / Terramite rebuild PT 1 VIDEO #18
Lifting the back of a car off the ground is pretty impressive for a TLB of it's size. I agree, I would say that the pump is working fine. The problem may be in the control block. Like you said maybe a bad bypass. A little tinkering and you should get it figured out.
Steve
Part 10... working on the pedal and new tires!!!
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A55973)
2015 Freightliner...
(2) 225/75D15 TIRES W/ 5 LUG RIMS (A52708)
(2) 225/75D15...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
JOHN DEERE 9 SHANK CHISEL PLOW (A52708)
JOHN DEERE 9 SHANK...
