terminology
/ terminology #1
rtd
Athens, Ohio
Ford 3930 - Kubota L3430 - Kubota B2150 - YM155D
In looking at a lot of ads, I find the self-explanatory terms 2WD and 4WD. What is MFWD?
Thanks
/ terminology #4
Nicer than full time four wheel drive. Can usually be engaged on the fly.
/ terminology
Thanks for the replies.
In a 'normal' four-wheel drive arrangement I can move a lever to add front wheel drive. I then will have one front wheel and one rear wheel pulling, assuming that I don't have the diff lock engaged. How is MFWD different? Would one work in 2WD, then shift while moving into 4WD? I assume to possibly use less fuel and save wear on the front tires.
I've seen the MDWD tag given on some ads for not very sophisticated machines. Perhaps the dealer doesn't know the difference.
/ terminology #6
On My tractor the clutch for mfwd is electrically controled. At he flip of a switch the clucth pack engages and the drive shaft to the front axle is powered. When braking, the computer engages mfwd to help braking.
I have heard with mfwd you have about 50% more pulling power than when in two wheel drive.
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
20in Single Cylinder Grapple Bucket Skid Steer Attachment (A61572)
20in Single...
2016 Dodge Grand Caravan Van (A61574)
2016 Dodge Grand...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2016 Ford Fusion Titanium Sedan (A61574)
2016 Ford Fusion...
