temporary relay defeat
   / temporary relay defeat
My owner manual does not ID the relays. From the schematic, I am pretty sure the gray relays are not the timer; they appear to be Neutral start, PTO safety start, ect. The yellow one appears to be for the turn signals.
I'm guessing it is one of those at the bottom of the picture. One is partially obscured by the wire harness.
   / temporary relay defeat #12
It's the blue topped one in the lower left of your picture that says "NGK Lamp Timer." Look closely and you'll see it has a special New Holland part number. Don't even bother trying to find a replacement. It probably exists, but is hidden in secrecy so you are stuck paying "full fare.":(
BTW: Is that good high quality organic dirt from California?;)
Yup, that there is the finest in foothill Auburn/Gabro soil sample collections :D
Online the timer is $67. I'll have my local guy order it(probably same price, but has been real good to deal with on the old Farmall I used to have, and my old Kubota).
   / temporary relay defeat #14
Robert, I looked at the circuit and there is a simple jumper you can do to get the tractor started if you want. The glow plug TIMER just supplies a ground to the coil of the glow plug POWER relay. With the plug removed from the TIMER, jumper pin 3 to pin 6 in the plug and you'll get glow plugs ON. Hold this for 5 or 6 seconds, remove jumper, and then quickly hit the ignition switch and I'll bet it will fire right off. This is a low current circuit, so a tiny little jumper wire will work fine.
Edit: If you look into the back of the plug, pins 3 and 6 are the pins where the black and brown wires attach. The orange and white wires are power to the timer.
   / temporary relay defeat #16
This is handy to know. I've replaced this timer once. The next time I'm installing a puch button which will make me the timer. Now I know how to connect it.
   / temporary relay defeat #17
Me too! Fool me once, shame on you. Fool me twice. . .ain't gonna happen.:D
   / temporary relay defeat #19
You know, Robert, if you drag this out long enough, it'll be summer and you won't need the darn glowplugs.;):laughing:
This afternoon. It is out of the 20's, and at 55 yesterday; sure it would have started. But, it woulda started rough. I don't think the timer has worked since I got this thing last year(Super Bowl Sunday...). It'll be for the best :D
Now off to shop and stuff for wife's bday... priorities...
2021 Ford F-250 (A55973)
2021 Ford F-250...
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
2017 Freightliner Bucket Truck (A55973)
2017 Freightliner...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
