Temperature Gage Reading
   / Temperature Gage Reading #1
Spaceman
Ct
Kubota B2100
I have a Kubota B2100 and the temp gage barely gets above the cold mark. Is this normal or should I change the stat?
   / Temperature Gage Reading #2
The gauge on my F2400 has a break in the line just above the cold end and that is where the needle sits when the engine is warmed up. I don't think you need to change anything.
   / Temperature Gage Reading #3
My B3030 when I had it was the same way, just above cold when warmed up. Only time it ever got higher was in the heat of summer with the cab AC on :D
   / Temperature Gage Reading #5
My Kubota B7510HST ran that way. Only time the gauge moved upscale much is when air flow became restricted through the radiator during mowing with the brush hog.
   / Temperature Gage Reading #6
My kubota MX5000 will not even move the temp guage to the half way point when work at PTO speed all day on a hot summers day.
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
