Temp on my Yanmar 1500
/ Temp on my Yanmar 1500 #1
Anonymous Poster
Epic Contributor
Took the tractor out to do some tilling. Had put a temp gauge on a few days ago. After tilling about 15 nmin I notice the temp over 250 deg. Tractor did not get hot. I pulled the gauge and checked with boiling water and water boil at 212 on the gauge. What going on??? :(
/ Temp on my Yanmar 1500 #3
The 1500 has no water pump. To cool correctly, make sure you have 25-40% anti-freeze to water ratio, no more. Also, make sure system is full, with no air pockets.
Jim
/ Temp on my Yanmar 1500 #4
In my opinion, 250F is too hot. Like as been posted several times before, you probably need to flush the cooling system, make sure fins are cleaned, and limit the coolant to 20-30%, and so on. According to what I was told sometime back, if you had the original water temperature sensor, the light should come on at 248F (+/- 5.4F) and go off at 233F (+/-5.4F). So based on temperature you were reading, you were right at the overheating point.
The highest temp I've got my YM1500 up to so far is 235.
I've read that 230 is OK, and I've also read about the "idiot" light coming on at 248.
If you have a screen over the radiator, clean it often. It makes a big difference. Also, it seems like the engine actually runs cooler (a little) if you run it around 2200 RPM. I assume faster engine speed equals more air flow (fan) equals lower temp.
I am running straight water with no anti-freeze as it's not necessary (Florida)and straight water cools better. My next project is an engine and radiator flush. I'll replace with straight distilled water and "water wetter" which is supposed to lower the operating temp.
Anybody use "water wetter"?
/ Temp on my Yanmar 1500 #6
Rick, I know you don't need antifreeze to prevent freezing, and maybe straight water is the right thing for you, but I guess you know that antifreeze also contains a lubricant (good for the water pump) and rust inhibitors (good for the entire engine) and will raise the boiling temperature. So I thought everyone ran antifreeze year round in everything now-a-days.
Of course, I'm old enough to remember when cars didn't have pressurized cooling systems and coolant recovery jugs, and lots of people put antifreeze in the radiator in the Fall, drained it out in the Spring, and put in fresh water, but they also usually added a can of water pump lubricant/rust inhibitor. If they didn't . . . ., well, we sold water pumps, too. /forums/images/graemlins/laugh.gif
/ Temp on my Yanmar 1500 #7
<font color="red"> </font> Also, it seems like the engine actually runs cooler (a little) if you run it around 2200 RPM. I assume faster engine speed equals more air flow (fan) equals lower temp.
<font color="black"> </font> You should be running it at 2200 to 2400 all the time, as that is what they are meant to be run at when working
/ Temp on my Yanmar 1500 #8
Bird,
The 1500 doesn't have a water pump, so the lubricant is not necessary. The rust inhibitors would be useful. The problem is that using antifreeze in these engines without waterpumps inhibits the natural convection (thermosyphon effect) that the engine relies on to circulate the coolant. As long as the rust inhibitor doesn't also inhibit that effect, then it's OK. For me, I'd rather run the risk of rust and deal with its effects, than overheat the engine and warp or even crack the head. As long as the system is clean, and a proper radiator cap is installed, it should cool as it is supposed to with just water.
/ Temp on my Yanmar 1500 #9
Regarding lower temps at 2200 rpm, I obersved the same on my YM1700. It seems that 2000-2200 would keep the temperature down by a good 10-20 degrees.
/ Temp on my Yanmar 1500 #10
Gregg, I had a Kubota without a water pump, too; same type cooling system. It came from the dealer with antifreeze in it, but I know you don't want to go too high a percentage of antifreeze for it to work properly. I wasn't sure which cooling system your Yanmar had. And pure water may be the right thing, I don't know. I just know I'd be concerned about rust, and I also don't know what effect, if any, adding rust inhibitor to the water would have, but doubt that it would hurt anything at all.
/ Temp on my Yanmar 1500 #11
The reason it cools down when you run it at higher RPM is because it has more HP at higher RPM. Your PTO hp is rated at 2400 RPM, below that it drops of significantly. I tested a yanmar 1401 and at 2400 RPM it had 15.1hp at the PTO. at 2000 RPM it had 8hp. I know it seems like it is going to fly apart but runnig a tractor at an RPM that it is not rated for does far more damage long term
/ Temp on my Yanmar 1500 #12
Maybe I wasn't clear, my 1700 runs cooler at 2000-2200 than it does at full throttle (2400). It may be a fluke or just in my mind, but the engine temp seems to run at least 10 degress less at 2200 than it does at 2400.
/ Temp on my Yanmar 1500 #13
Have your rad. cleaned by a rad. shop, reinstall, flush system,
problem solved.
/ Temp on my Yanmar 1500 #14
RDAM, "Water Wetter" works great. I drag raced in the NHRA division 7 for several years. My home track was Firebird Raceway in Phoenix, AZ. Most of the guys I know ran distilled water with the Red Line company's "water Wetter" product. It did help high performance engines run cooler in the desert. When racers use the product in the heat, it should be a good endorsement for it's effectiveness. Red Line does not reccommend the use of ANY coolant wqith the product, only water. I have not used it in my 1602D because I am now living in Minnesota and don't have any overheating problems no matter how hard I work the Yanmar.
Jim, Machinefarmer
Does anti-freeze raise the boiling temp? I didn't realize that? I thought that was purely a function of the pressurized system. I was aware of lubricants and rust prohibitors. However, I think you can buy a rust prohibitor by itself.
As the name suggests, it clearly LOWERS the freezing temp
All antifreeze both raises the boiling temperature and lowers the freezing temperature by putting particles in between the water molecules. We use light weight molecules suchas salt on the roads (which would of course corrode engines) or ethylene glycol in engines). The change in boiling/freezing point is proportional to the number of particles added per unit volume (i.e. the more you add, the more the temperature changes at which you can freeze/boil the water).
Pressure also raises the boiling point--thats why radiators have a pressure cap.
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2020 JOHN DEERE SUV590M S4 GATOR (A60430)
2020 JOHN DEERE...
Gravely ZT 1540 40in Zero Turn Commercial Mower (A59228)
Gravely ZT 1540...
