Temp light
/ Temp light #1
sirgknight
South Georgia
Early model YM1700
Ref 1700: tractor has three red lights on dash - TEMP CHG OIL. The charge and oil lights come on when I start the tractor but the temp light doesn't come on at all. Shouldn't it come on when the switch is on and go off when the tractor cranks? How and what can I check for process of elimination to problem? Thanks.
/ Temp light #2
The temp light will only come on when the engine is too hot. To check the light and wiring you will need to unplug the wire from the sender on the engine and touch it to a grounded metal surface or to the battery - terminal. The light should come on. The only way to tell if the sender is functioning is to put it in boiling water and see if it closes the circuit.
Hope this helps,
Aaron
Parts@HoyeTractor.com
(940) 438 0386
/ Temp light #4
I, as well as many people here have replaced the light with a temp gauge. Sunpro offers a fairly nice gauge. I have a YM2000 and had to use the metric adapter kit, you may have to do the same. Adding the gauge has settled my nerves.
/ Temp light
I've gotten so accustomed to gauges I had almost forgotten the term "idiot lights". A gauge is definitely in order for this situation.
/ Temp light #6
callais,
Were you able to use the adaptor that came with the gauge or did you need to buy something else? It is really an uncomfortable feeling knowing the life of your multi-thousand dollar engine can depend on a single bulb working properly.
Aaron
(940) 438 0386
/ Temp light #7
I had to buy the metric adapter kit, It came with 3 other fittings. The metric fitting I used was also a lower profile to allow the sender to sit lower into the block. The gauges are DEFINITELY the way to go, I was never comfortable waiting for my tractor to get to 265 degrees before a light may or may not come.
/ Temp light #8
If he bought a sunpro gauge he probably also bought the metric pack that is optional for it. At my local stre.. the sunpro gauges are 9.99... and you can buy metric adapters for ?5.99. I havn't specifically looked at the water bulb.. so am wondering how the bushing works.. must be some pretty big adapters...?
Soundguy
/ Temp light #9
Thanks for the thread, this answered my next (and certainly not last) question about my tractor. I would love to see some pictures of these guages installed. My next project is to add guages to my tractor and would like to see how they look installed, and hear any tricks to installing them.
thanks
--Scott
/ Temp light
Thanks everyone for all the great input. I know what next weeks project will be!
/ Temp light #12
Sydken,
here are some photos of my gauges installed. First is the dash with Sunpro 1 1/2" gauges...and I left the low oil pressure warning light.
/ Temp light #13
Here is the oil pressure with "T" adapter to allow both the old sender and the new gauge copper line.
I have 1 1/2" gauges, but also bought the metric adapter, "T" adapter and copper line kit from Sunpro. The 90 degree angle and short connector I got at Autopro for a few bucks.
Sorry I do not have a photo of the water temp connector, but it is a simple removal and replacement..but also required Sunpro's metric adapter kit.
John Deere 757 Zero Turn Mower (A66285)
John Deere 757...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
John Deere 6400 (A64126)
John Deere 6400...
2026 Electric Tricycle (A64194)
2026 Electric...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
