temp gauge
/ temp gauge #1
texas
satoh st1620 4cyl diesel
where should my temperature run while working my ym2010. also, is it normal for the tractor to jump when shifting gears on the go keeping a steady throttle, it is a powershift model. thanks chris:thumbsup:
/ temp gauge #2
It has a thermostat. Not sure what set at , but probably 180*. If by jumping you mean slamming into gear like speed shifting any standard trans. I would say that's probably normal.
/ temp gauge #4
If you use the clutch during high RPMs it will stop the wheelies and its easier on your ring & pinion gear.
The power shift was not meant to be shifted (without) the clutch at real high RPMs.
Although, wheelies are fun if you have a roll bar ;) ;)just joking...
/ temp gauge
thanks for the help. mine already has some slack in the ring and pinion, i will use the clutch or just start off in the gear i need to be on the safe side. my temp gauge stays between the 1/4 and 1/2 way mark. put about 3hrs on it building a house pad and it did great. :)
4004SFL (A59228)
4004SFL (A59228)
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
John Deere 6125R (A60462)
John Deere 6125R...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
TANK MANIFOLD (A58214)
Electric Concrete Mixer (A61166)
Electric Concrete...
