Tearing down cement block silo.....
   / Tearing down cement block silo..... #11
1. Add in paper.. silo free you remove... makes great paving stone
2. make s hooks 3ft long, bottom squared off to hold 2x12, climb chute and hang on sides to scaffold a ring around inside, reach over and loosen top ring, remove short blocks that will be every third block likely, reset hooks and remove next longest, then longest ones. keep resetting hooks and 25 trips around you should be able to stand on the ground. it will take two people at least, extra hooks. planks about 6ft long,safty harness and paid up insurance on you and your buddies. We have done this to install tripods on top of silos but it is real scary and not for the faint of heart.
3. build circular stairway and build a lookout room on top.
   / Tearing down cement block silo..... #12
However you do it make sure to have the video camera going. Ya never know....................you might make some money on it. (Video of how to do it or how not to do it) /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
TBAR
I most certainly thank everyone who has taken the time to offer suggestions or laughs.I like the shotgun idea best...tss cheap anyway.I can save at least $5 on the beer since I gave that up years ago.If I paint a whitetail on the side....I wouldn't have to buy slugs...the neighbors would have it down by the end of the rut!!I may just fire up the grill and get my buddies together and break out the 54 cal. front stuffers.'Couple of good volleys might do it.The wife has offered to run the camera...but she has no idea what that amount of black powder sounds like!For the fella who wanted to know where we are...exactly half way between the Fort Wayne TSC and the Columbia City TSC.
   / Tearing down cement block silo..... #14
I watched a guy tear down a silo using a long cable and a large excavator. He climbed onto the bucket of the excavator, the operator then slowly raised the bucket, as high as the machine would go /forums/images/graemlins/crazy.gif, and the guy attached the chain/cable near the top. The operator slowly lowered the man to the ground, who then hooked up the cable to the bucket. The operator then backed up, and pulled the silo down. /forums/images/graemlins/grin.gif
   / Tearing down cement block silo..... #15
We had a silo in the way when my parents bought a golf course back in the 70's.
We hired the local & retired Ag teacher who promptly blew it up early in the morning. Large rocks blew several hundred feet up and over the hill.
From the earth quake, the locals from many miles away knew who was up to what, they just did not know exactly where.
Nobody got hurt, no buildings were damaged, and many lasting memories.
Yooper Dave
   / Tearing down cement block silo..... #16
This is dangerous work, so I'm just conversing, not suggesting anything.
The scaffold planks & S hooks works if you want to save the staves. Pile some loose hay/straw at the bottom. Probably won't save you, but most of the staves will be saved. This requires people not afraid of heights & heavy work.
Or, you take a sledge hammer, pound out every other stave at ground level 1/2 way around so it looks like a grinning pumpkin. Put a good strong chain through it. Attach the chain to a much longer stout chain/ cable. Attach to a strong tractor or crawler. Pull. The remaining staves will pop out like loose teeth as the chain pulls on them, the silo will (well, should) fall towards you (remember the _long_ cable part?). Have life insurance paid up, and it's pretty obvious the risks of knocking out every other stave on an old weak silo.....
If this is a concrete _stave_ silo either way works. For a _block_ silo, you probably need professional demo equipment.
--->Paul
   / Tearing down cement block silo..... #17
I'm in the same boat as bobodu, as far as the silo goes anyway. unfortunately it is only about six feet from my barn, and i don't want the barn damaged. Any idea how much your friend gets for taking down a concrete silo, and is he in the phone book?
   / Tearing down cement block silo..... #18
boy I'm glad I didn't have any old silos to deal with! just about 30 or so junk piles scattered everywhere! I keep finding new ones every time i mow /forums/images/graemlins/mad.gif
anyhow one other choice if it can be blown up is if you have a good actelyne torch setup and a couple of big garbage bags?
they make BIG booms but not sure how much would take to open up the lower blockes enough for gravity to do it's think.
Up in akron there was a SMOKE stack that was 220 feet high. made with red brick! they hired a guy to take it down. brick by brick. setting on top with a big hammer and dropped the bricks down into the center. it filled up and was still almost 30 feet high if i remember right. but that was dug up and dropped into dump trucks eith a big excavator. it only took about a week or so if i remember right. was about 10 years back.
anyhow if you are attempting to remove it you're self be sure to pay the life insurance up and increase the benigfits to about 2 million. and add a dissability clause! lol
Mark M
Something horrible has happened since I started this thread.The DPO had left the thing filled with silage from more than six years back.Thought it would be great on the garden but when we popped open one of the lower doors we found the stuff to be as hard as clay!!! Takes me about an hour to chip out about half a yard.I wonder if there is a better way.The auger is surely frozen.I thought about an ice fishing auger to dig it out. /forums/images/graemlins/mad.gif
   / Tearing down cement block silo..... #20
I'm wondering about a power washer.....It could cut out reasonable chunks, moisten things up a bit....Might be messy, but it might be worth it.
2017 Jacobsen 3551 HOURS (A56857)
2017 Jacobsen 3551...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
