Tearing down cement block silo.....
/ Tearing down cement block silo..... #21
Bobodu,
New ad for the paper:
FREE silage to go. Haul at your own expense. Comes with free carry out container.
Good luck. Does it burn? (I can spell it from here just thinkin about it)
Ohmagod...I don't wanna talk about ANYTHING burnin' around here!! I was burning some cardboard last week and set the field full of wheat stubble on fire...something like 600 acres worth of fuel out there.I only burned a circle about 50 feet in diameter but it scared the daylights outta me.The neighbor said" At least you didn't have to call in the fire dept. like Tami did."Hmmm....oddly she never told me that story...I usually don't bother with her past before we were married but I had a lot of fun with that one.We are gonna move the burn pit...didn't get too much of an arguement since I now have a lil'leverage....
/ Tearing down cement block silo..... #23
bob: be carefull and NEVER get inunder the stuck silage. it is a very bad day for the fire men when they have to dig through all the old rotting stuff to find you and take you to the morgue!
Mark M /forums/images/graemlins/frown.gif
Oh yes...that thought has crossed my mind.I won't even stick my good tools in there for fear that they will be lost.I'm pretty sure that I will just be going for the manure down the road and let someone else deal with this one.Bob
/ Tearing down cement block silo..... #25
</font><font color="blue" class="small">( We are gonna move the burn pit... )</font>
Why??? /forums/images/graemlins/confused.gif
Everything around it burned already, right? Sounds like you already have the new burn pit already there! /forums/images/graemlins/wink.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
/ Tearing down cement block silo..... #26
Hey Bob,
Please keep us informed. I also have one of those darn things in my yard. It would be worth the drive to come up and watch if not intruding.
Mine is empty though. I miss out on all the good stuff!! /forums/images/graemlins/grin.gif
It's really sad,but the thing is not coming down soon.It actually belongs to the neighbors and they are getting a divorce...you can guess where this is going.....she got the house and I got the silo.....sorry.
/ Tearing down cement block silo..... #28
I had a couple taken down, not a problem, 2 ways to do it. One guy took a sledge, knocked out every other block in the direction he wanted it to fall, only half of the silo though. Then strung a heavy steel cable, hooked to a 100 hp tractor, thru the dia of the silo and started to pull. By pulling he popped out the remaining blocks, the silo laid down with a crash,,,,,,,, make sure you use plenty of cable though, If this makes you nervous, maybe you could get that ex to drive the tractor.
Later, I'll post a better way to do it.
/ Tearing down cement block silo..... #29
Test Picture
/ Tearing down cement block silo..... #30
We attached a cable at the top, caught a couple of hoops.
/ Tearing down cement block silo..... #31
Next we cut some of the bottom hoops, note the hole opposite each other, only one shows in the picture as the other is on the other side. We fed a cable thru the holes, had a small crawler on the other end, this popped the staves out.
/ Tearing down cement block silo..... #32
Next we attached the cable from up above to the excavator, to direct the fall of the silo.
/ Tearing down cement block silo..... #33
Cable at the bottom
/ Tearing down cement block silo..... #34
Evveryone says on last prayer
/ Tearing down cement block silo..... #35
Tighten things up
/ Tearing down cement block silo..... #36
Staves popping out
/ Tearing down cement block silo..... #37
The excavator came in handy here, maybe a bit to close though!
/ Tearing down cement block silo..... #38
Makes a little dust
/ Tearing down cement block silo..... #39
after the dust settles
/ Tearing down cement block silo..... #40
an 18' x 70' made about 4 trips to the dump
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
INSPECTION (A65563)
INSPECTION (A65563)
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
2019 TRITON TRAILER ALLMAND MAXI POWER 25 GENERATOR (A65643)
2019 TRITON...
