TD95D something I learned last summer
   / TD95D something I learned last summer #1
WTA
Platinum Member
The design of the condenser and radiator leaves something be desired. It's designed much more like a car than a tractor from the old days, Smaller, more fins per inch and not very well shielded from debris at all. I mowed 400 acres late last summer of old dried out crp grass and tall weeds with a big 14 foot shredder. I was doing great power wise but after about the first hour I had to drive it back to the house to investigate an overheating problem. The condenser was completely choked up with lint and pollen. It slides off to the left easily so it can be blown out so I did that and went back to work. About 30 minutes later same thing. I came back and blew it out again. I went through this routine 3 or 4 more times and came back and discovered the radiator was just plugged solid with pollen and dust. Looking at that thing it seems to me it would be more at home on a car than a tractor. It's pretty thick to begin with with a very high fin count compared to my old super c or super M which NEVER even think about overheating. Just the perfect place to trap trash. I had to remove the battery, ac condenser and top bracket to flush it out with a water hose adequately. What a pain! Throughout that 400 acre job this was an every 3 hour event. I also blew out the outer air filter, cabin filter at that time and took a portable air tank with me to blow the condenser every 30 minutes. Now my air intake has a 2.5 inch snorkle on it going up to cab top height and that helps a lot with the air filter! I'm looking for a precleaner to fit it today. The radiator never was a problem till I went mowing in a high dust environment but I thought I would mention this in case any of you live in an area like me. Overheating is usually something stupid and I'd hate to see someone else call the dealer over this.
Something else I have learned, This machine just absolutely loves biodiesel!!!!! We contracted for B100 made locally about 6 months ago now as diesel prices started too soar again. It's pure virgin soybean oil made stuff. At first I was nervous about running it after all my earlier fuel problems so we went 50-50 for the first tank. I've been running straight since. In both my tractor and our 94 F350 powerstroke and 93 f250 IDI truck. The only problem I have had was a dripping o ring that only dripped when it was below freezing on the injection pump. (the pump that our dealer had rebuilt a few years ago when they were throwing parts at it) I replaced it myself and found out it was nicked pretty bad when they put it back on so..... It wasn't the fault of the biodiesel. So far I have not lost any mileage on anything, nor power. We've racked up almost 30,000 miles on my f350 with it too. The trucks and tractor do tend to smoke just slightly more but not enough that anyone else would notice it.
ANyway, I'm paying 3 bucks per gallon for high quality bio diesel and pump prices are at 4.09 as I type this. So if anyone else is looking to save money........And help your engine with fuel that actually lubricates still.
   / TD95D something I learned last summer #2
I've often wondered why tractors don't come with a small air compressor as an option. With that and a short hose, you could blow out debris and keep on working instead of having to go back to the barn/house. Heck, they put windshield wipers on cabs so you can see better. Why not put a small air compressor on that tractor too. Maybe they are available and I'm showing how little I know about bigger ag tractors.:confused:
   / TD95D something I learned last summer #3
I've been thinking of adding a precleaner to mine if I can find one that fits in the intake of the aircleaner housing. I haven't had a problem since I got the machine in late fall. I just like precleaners on general principles.
I'll keep the rad/condenser problem in mind. I haven't looked but is there anyway to put a piece of fiberglass window screen over the radiator/condensor system that would allow you to just pull that off and get most of the duff that clogs the radiator?
Thanks for the info.
   / TD95D something I learned last summer #4
That reminded me about 10 yrs or so ago a customers Kubota G6200 mower kept overheating,they wouldn't keep the debris cleaned out of the radiator.I didn;t like the way it was designed either,just like a car radiator.I had a local radiator shop put in a core like the old Ford tractors,with wavy horizontal fins and stagered tubes,with 1 more row of tubes added.Worked fine and was easy to keep cleaned out.That was the "old days" these modern radiators would be difficult the way they are built and the materials that are used.
I think if you made a steel frame to hold a piece of window screen it would be easy to attach. My neighbors Kubota came with one. It's a pretty fine mesh steel screen. I've had to clean it every time I use the thing. He never even opens the hood. So it must be working.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2017 FREIGHTLINER...
154 (A52708)
154 (A52708)
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60460)
2014 Chevrolet...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
2018 Peterbilt 567 T/A Day Cab Truck Tractor (A60460)
2018 Peterbilt 567...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
