TC40D-Rear Work Light on Rops
   / TC40D-Rear Work Light on Rops #1
Jeler
Iowa
New Holland TC45D, 1937 Unstyled JD Model A, Ford 8N
Good morning from Iowa
I have a '05 TC40D and wanted to add a rear light for moving snow this winter.
I've located the quick connect wire behind the seat to the right, but when I test it, there's
no power there. I checked the fuses, esp. the turn signal fuse which is on supposedly the
same circuit according to the manual.
Here I thought this was going to be a simply install, but I literally pulled my hair out
yesterday trying to figure out the problem. I even removed the left hand cover/cowl below the steering
wheel looking for the obvious, to no avail.
Has anyone else ever encountered this problem? I tried the switch in ACC and even started the tractor
up to see if I had any current, but got nothing.
Jeff
   / TC40D-Rear Work Light on Rops #2
Jeff,
I've never used the aux. power plug on the back of my '03 33D but did a quick power check. It has power when the key is rotated and stays on while the tractor is running. The schematic in the manual indicates a switch but there is none. Operating the light switch has no effect on it.
Maybe you have a short in the line somewhere?
Larry,
Yes I'm afraid a short is probably my answer, all though hoping it was just a wire / relay I needed to connect
below the fuse panel. The light shown in my schematic has a switch located on the light itself.
Thanks for the Reply
Jeff
   / TC40D-Rear Work Light on Rops #4
Larry,
Jeff
I've had a work light plugged in for years ('05 model TC40DA) that has a switch built in the plug. I got the plug at RS and just used a 12v work light. I suspect you have broken wire or short. But first, I'd make sure the contacts inside the plug are clean and that you have a good ground.
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2019 KOMATSU  D65 PXI 18 (A52472)
2019 KOMATSU D65...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52748)
Marliss Industries...
