TC40D-Rear Work Light on Rops
   / TC40D-Rear Work Light on Rops #1
Jeler
Iowa
New Holland TC45D, 1937 Unstyled JD Model A, Ford 8N
Good morning from Iowa
I have a '05 TC40D and wanted to add a rear light for moving snow this winter.
I've located the quick connect wire behind the seat to the right, but when I test it, there's
no power there. I checked the fuses, esp. the turn signal fuse which is on supposedly the
same circuit according to the manual.
Here I thought this was going to be a simply install, but I literally pulled my hair out
yesterday trying to figure out the problem. I even removed the left hand cover/cowl below the steering
wheel looking for the obvious, to no avail.
Has anyone else ever encountered this problem? I tried the switch in ACC and even started the tractor
up to see if I had any current, but got nothing.
Thanks
Jeff
   / TC40D-Rear Work Light on Rops #2
Jeff,
I've never used the aux. power plug on the back of my '03 33D but did a quick power check. It has power when the key is rotated and stays on while the tractor is running. The schematic in the manual indicates a switch but there is none. Operating the light switch has no effect on it.
Maybe you have a short in the line somewhere?
Larry,
Yes I'm afraid a short is probably my answer, all though hoping it was just a wire / relay I needed to connect
below the fuse panel. The light shown in my schematic has a switch located on the light itself.
Thanks for the Reply
Jeff
   / TC40D-Rear Work Light on Rops #4
Larry,
Jeff
I've had a work light plugged in for years ('05 model TC40DA) that has a switch built in the plug. I got the plug at RS and just used a 12v work light. I suspect you have broken wire or short. But first, I'd make sure the contacts inside the plug are clean and that you have a good ground.
MASSAGE CHAIR (A58214)
2018 John Deere Z997R (A53317)
2018 John Deere...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
1992 BYQ Boat and Trailer (A56859)
1992 BYQ Boat and...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
